yoke at t-case
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by mccomas, Nov 11, 2003.
  1. mccomas
    mccomas 1/2 ton status
    May 30, 2003
    262
    Fayetteville, NC
    i thought this fluid was coming from my u joint so i replaced the u joint and steam cleaned the shaft and sounding area. after doing this, my rig set for a few days without being moved. when i went back to it and looked underneath, i could see that the moisture was transmission fluid. the yoke that slides into the transfer case is hollow - is it possible that i have a crack at the bottom of the yoke shaft (driveshaft end) and that the fluid is seeping through? anyone else experience this? the seal at the transfer case is dry so i am sure that it is not coming from there...
  2. reeser
    reeser 1/2 ton status
    Oct 8, 2001
    434
    Hayden Lake, ID
    yes it is possible that the 'slip yoke' could be cracked or the tailshaft housing of the t case is cracked or the rear seal is leaking. i would inspect the case for noticeable cracks before doing anything else major. the weakness of the aluminum case is the downfall of the newer 208 and 241 t cases.
  3. VisionxOrb
    VisionxOrb 1/2 ton status
    Oct 10, 2001
    251
    Newbury Park, Ca
    If it looks like its leaking out of the yoke its self then it probably is, theres a seal kind of like a engine freeze plug pressed into the end of a yoke, that could be leaking, happened to me, when ever id park with the rear facing down hill it would leak pretty fast actually.
  4. bigjbear
    Feb 18, 2000
    13,970
    451
    Marietta GA
    I'll 2nd that guess. Mine leaked from that plug untill I replaced it due to other damage.
  5. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    The plug is not structural so you can just silicone it if it is leaking from there. I have a newer slip yoke I need to get rid of if that doesn't work.
  6. mccomas
    May 30, 2003
    262
    Fayetteville, NC
    fubeca, i just ordered a slip yoke for 65.00 - like 10 mins ago. i may have been able to fix it up with some silicon but i have a pretty good transmission leak and i wanted to be sure to eliminate this one. once i get this installed, i will post a pic of the leaking transmission and try to get some advice on fixing it...
