yoke-side pinion bearing
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by aburnett, May 12, 2003.
  1. aburnett
    aburnett Registered Member
    Oct 25, 2002
    30
    Birmingham, AL
    OK, 1st problem. My blazer makes consistant whining-type sound which made me think that the Pinion nut was too tight and maybe messed up the crush sleave. The rear end leaked anyway, so ive removed the diff and pinion and check it all out.
    Anyway the finished surface that the bearings behind the pinion oil seal roll on have a roughed-up "spot" about the size of your finger tip.
    Could this be the culprit? The rest of the parts are in good condition.
    Can it be removed? and if so how? What is the name of the part so I know what to shop for.
    I am barely above novice mechanical-wise.Sorry if I left any usefull info /forums/images/graemlins/confused.gif
    Info:
    77 K-5
    12 Bolt 3.73 Diff
    Stock
  2. aburnett
    Oct 25, 2002
    30
    Birmingham, AL
    ok, i did some more searching on previous posts, and its the outer race i need to replace. the bearings seem ok, but I will replace them anyway since im this far into it.
    As far as the race. I guess i need to invest in a slide hammer. Any tips on replaceing the race with the least amount of grief?
  3. aburnett
    Oct 25, 2002
    30
    Birmingham, AL
    Update:
    Nevermind. Everything is under control.I managed to knock it out from behind with a floorjack handle and hammer.
    Smooth sailing from her on out. Ill try to do a better job searching the old posts.
  4. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    You had a thread all to yourself question and answers /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif. J/K Glad to see ya got it all worked out.
    -Brian
