Yoke Swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Big10, Mar 4, 2003.
  1. Big10
    Big10 Registered Member
    Aug 30, 2002
    84
    Georgia
    Are there any real concerns with changing the rear yoke besides torque' on the pinion nut? Is there anything else that I have to do?
  2. dyeager535
    26,975
    After mine continually loosening up and destroying the seal, I locktited the nut, and siliconed the surfaces that *might* leak...the washer to yoke surface mainly.
    The pinion nut torque is fairly critical, but my experience has been that if you tighten the yoke as much as possible with a decent sized ratchet, on an already setup ring/pinion, you'll be fine.
    Like I said, mine came loose multiple times (3) and each time I tightened it up, with no audible problems. Usually the gears will howl, etc., if the ring/pinion aren't meshing correctly, so I figure it's "close enough". I've now been driving on it over a year, and no problems.
    I'd not go with too big a bar, as you could conceivably crush the sleeve in there. That takes a lot of force, and with the axle in the vehicle, you'd have to work to get something large/long enough to crush it further in there. (or perhaps use an impact wrench)
