yoke
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JJ85K5, Feb 14, 2002.
  1. JJ85K5
    JJ85K5 Registered Member
    Jan 2, 2002
    21
    So Cal
    what's the pro's and con's of a slip yoke vs. a fixed yoke? is there a major difference?
    JJ85K5
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    The slip yoke is a bogus design. It has no pro's. The fixed yoke is the way to go.
    **WARN**ing, Something winching this way comes! [​IMG]
    <a target="_blank" href=http://www.mccords.s5.com/myk5/index.htm>NashvilleK5</a>
  3. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Slip yoke, if the shaft brakes your stuck less you wanna drive around with no fluid in your T-case.
    Slip yoke, if you have a "really" flexy suspension, your slip yoke could slip out of the back of the T-case.
    Slip yoke, the spline wear down after a while and cause a binding clunk noise when releasing the brakes from stopping.
    Fixed yoke, eliminates all those problems.
  4. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Umm! Isn't it stronger too?
    Mudstud
    <a target="_blank" href=http://communities.msn.com/OffroadK5s/6superliftand33s.msnw>http://communities.msn.com/OffroadK5s/6superliftand33s.msnw</a>
    76K5 6" with 33s, sb400/350/203parttime/3.73-D44/GM12bolt
  5. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Yeah, that too.
