york- but not york- style a/c compressor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, Mar 24, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    pulled drivetrain out of a 78 van today, 350 and th350, has an aluminum case cylinder upright style a/c compressor, but not York brand, dealer instaleld system, would this be any good as an air compressor conversion candidate ?
    anyone know which one i am talking about, are commonly seen on older engines instaleld by dealers
  2. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I think as long as it has it's own oilreservoir it will be OK. The ones that are lubricated with the additive that goes in the gas will not work, at least not for long.
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    I have heard that the dealer installed units were Yorks. Maybe the tag is missing.
  4. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    post a pic if you can, there were some yorks that were tagged different (do to names)
    where they really are yorks but had someone elses name on them.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    it has some other name on it and its not york, its bare aluminum colored aluminuum compressor, hope it didnt get tore up too bad when were pulling engine out of van, the cowl on the vans are so low and top of compressor ate the cowl alot when yanking engine out, hmmm, i havent really inspected yet
    thanks
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I bet it is a York.
    That would mean you have the [CrockHunter]Elusive[/CrockHunter] York SBC mount.
    Where did it bolt up?
    I found one on a 73 p/u and it was mounted right on top of the water pump and had 2 idler pullies on it.
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    It is a York.
    I just pulled 2 this week end at Pick N Pull.
    York was a supplier to lots of OEM and you see them under many names, but they are all York.
    It's funny though I only find them in Vans with the 350, never in a pickup or blazer.
    Good score /forums/images/graemlins/thumb.gif
  8. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    Yep, probably a York. There were quite a few vans that had Yorks put on them, though it's in a really bizzare place. Works great for a van since it's engine location, but I'm not sure how it'd work in another vehicle.
    If you put it in make sure to post some pictures. I'm curious how much clearence you'll have.
  9. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well it's not higher than the air filter housing, but if it's tight a body lift should cure that.
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    couple idlers and is where alt would be on the old 67-72 trucks, is about as high as teh breather with the base spacer and all that you find on vans and 67-72 trucks 4 bbl, ill have a digicam finally after allt hese years ehre in a few days maybe ill get some pics
    thanks
  11. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    It could also be a Techumsah (sp) compressor. I have one of them on the shelf at work. Looks VERY similar to a York.
    Take a look here for some info on all different tpyes of compressors.
  12. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    its not that either, i knew the name on the tag on it but i forgot it now, hmm.., ill try and remember to post tommorrow
  13. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
  14. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Looks a bit different from a York to me, must be a clone of some kind. Here's a pic of mine froma similar angle -
    [​IMG] </font>
  15. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    how did you post directly ? i cant get img or image brackets to work on the forum unlike on others
    thats about 90% identical to mine, i forgot again today to get the name off the tag sinc ei had forgotten it the other day, hmm.,,.
    thanks
  16. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Yahoo probably won't allow you to link directly. Yeah, it looks aalmost the same, but I don't know if York ever used different castings. There are some off-brand York style compressors but the ones that I've seen appear to have almost the exact same casting. I wouldn't be surprised if the guts are interchangable. </font>
  17. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Maybe its an aftermarket replacement for a York?
  18. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    a york competitor probably im sure, what dealer was supplied with that the van was retrofitteded to a/c with
  19. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    I just picked up the same thing from the junkyard yesterday. It was mounted to a SBC, so I got the bracket to mount it too! It was in a catering truck so I assume it had something to do with the refrigeration. The tag on it says Borg-Warner and after I got it home and cleaned it up some, I saw it also says York in tiny printing in the bottom corner of the tag. According to this it can be laid down on its side. The mounting holes on the sides of the compressor match up with the ones on the bottom. If hood clearance looks to be a problem I might do this when I get around to mounting it. I may do it anyway just to get better access to the air filter and carb, but who knows. /forums/images/graemlins/usaflag.gif
  20. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If you are using it for OBA you can't lay it on it's side. It can only be on it's side for A/C.
