york clutch removal?
Discussion in 'The Garage' started by readymix, Feb 10, 2005.
  1. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Picked up a york of unknown size today at the junk yard. I can read the data plate but the numbers do not match anything found at On-Board Air. They are AMC-5461585 in case anyone knows anything:D
    Anyway. How do you remove the pully and clutch assembly. Do you really need the special tool or what?
  2. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    Remove the 1/2 nut in the center of the clutch assembly, then use a 1/2" coarse thread bolt and thread it into the center hole and tighten it up, as you tighten it, the clutch will come loose of the shaft. Don't loose the shaft key. It's in the shaft of the compressor and keeps the clutch and shaft alligned.
    It's real easy. don't be afraid to toruqe down the 1/2" bolt, it works like a puller.
    Rob
  3. readymix
    May 30, 2004
    6,706
    26
    Thanks for the info. Headed to the garage now.
    Anyone know about the numbers?:1zhelp:
  4. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    IIRC, mine took a 5/8" coarse bolt. An impact wrench was an absolute necessity also. Every other attempt I made failed miserably.
    This is what my tag looked like. The "10R" was for 10 cubic inch, and right hand suction I believe. It also had a manufacture date of 04/01. The 2 before the 10 is for 2 cylinders. 25212 is the part number. F is for flange cylinder head. E is for equipment (heavy duty) as opposed to "SC" for sub-compact. I'm not really sure about your numbers, but page 4 here might help.
  5. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    Yea I used a 5/8 coarse thread...and with no impact wrench it was rediculously hard to get that thing off...but enough elbow grease can make it happen...
  6. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
  7. readymix
    May 30, 2004
    6,706
    26
    I got the clutch off and from looking at the shaft it is a 210R :D:D
