york compressor not on truck
Discussion in 'The Garage' started by 69K5, Jun 1, 2003.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    sittin at my friends house bored, got us to thinking for once. he has a york compressor (long stroke), an ac motor that runs off of 110v, and an air compressor that the 2h burnt up on so it still has all the shutoff valves attatched. my qusetion is could the york handle the constant 2500 rpm that the motor turns?
    nathan
  2. got_mud
    got_mud 1/2 ton status
    May 9, 2003
    316
    Wichita, KS
    york says that the ideal run rpm is between 1500 and 1800 at the shaft. if you can use a set of pulleys to reduce your compressor speed to that you should be okay. it won't hurt them to run faster, they just push hotter air out and need a shorter duty cycle.
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    cool thanks for the tip. we already had it ready to go just trying to check it out before we fried it.
    thanks
    nathan
