york compressors who's got one
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beater74, Feb 18, 2002.
  1. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    york compressors who\'s got one
    okay here's the deal i'm looking for bracket ideas so i can mount my york compressor. the write up on the tech section is great and it is right when it says the hardest part of the whole thing is making the bracket! I've got a very simple engine set up the alt. is on the pass. side and power steering on the drivers side. theres no A/C or any of that fancy stuff in there. the one idea i had was to fab a bracket so it attachs to the drivers side head and uses the power steering pump as the tensioner but i'm alittle leery of hanging 30 pounds worth of compressor off the side of the head. what do you think or got any pics.
    gime a bucket of chicken with extra skin!
  2. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    Re: york compressors who\'s got one
    Hey, ive got the same prob. im runnin it off of my ps pump. I pulled mine from an Fo*d Bronco. I took the bracket, which i think i will mount the bottom of it to the ps pump tensioner,and make a piee to bolt the other side into the block. My hardes part is finding a belt. i think i will need a 41" belt, and i should be set. O if u know n e one else that needs a compressor, let me know. i think i can get another one for $10-$20.
    NITRO
  3. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I need a compressor.
    Houston, TX
    <a target="_blank" href=http://community.webshots.com/user/cegusman>http://community.webshots.com/user/cegusman</a>
  4. BLUESMAN
    BLUESMAN 1/2 ton status
    Oct 3, 2001
    951
    Phoenix(but it\'s a dry heat...like an oven!)AZ.
    Let me know if you can get another "York" compressor, I'll buy it and shipping.
  5. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    I have a 88 tbi set up so i used the pump as the tensioner and put the york to the left of the altenator. cegusman go to any pic a part in houston, their are three of them. There are tons of them out there. Make sure you get the largest capacity one!!!! - Doug
    Doug Krebs
  6. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    www.onboardair.com makes a bracket kit for 88-96 pre vortec engines. I have one and it is pretty cool
  7. beater74
    May 29, 2001
    1,749
    atlanta
    yup saw that, but notice 74 in my sig that makes it a pre 88 engine plus that braket is for serp. belt setup. unless it can be modified to work on mine plus it's very spendy$$$$$. thanks
  8. BigBadCad
    BigBadCad 1/2 ton status
    Dec 18, 2001
    109
    minneapolis, mn
    I made a York bracket for my 500 caddy that were cheap and easy to make. The only thing I had farm out was an 3/8ths milled slot to adjust belt tension the rest was done with basic hand tools, and a little torch and welding. I haven't checked, but I think you could set up a SBC or BBC in a similar fashion. If you would like some pics I will pass them on.
    1980 chevy 4x4 1-ton crewcab, 500 caddy, York OBA...work in progress.
  9. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    If you could post them, that'd be cool. Or send the pics to me. That is my next big project. Of course, I may have fun as I have p/s and a/c. Maybe I can put mine where the AIR pump used to be.
    Brian
    Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
  10. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    I wouldn't worry much about the weight. That is similar to how an a/c compressor mounts. My a/c is mounted to the header bolt, the head on the front and the p/s bracket. And it easily weighs what the york does.
    Brian
  11. beater74
    May 29, 2001
    1,749
    atlanta
    picks please
  12. beater74
    May 29, 2001
    1,749
    atlanta
    yeh i think i got it figured out and i weight it last night and it weights 25lbs. now lets see if i can find a belt that will fit
  13. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    I have some pics of my setup. it's a 72, all i did was make a T out of a 3/8" slab that bolts onto the head with some spacers. check out the pics if you have more quesitons let me know.
    ARQ.
    offroad baja!!!
    72 4x4 CST Blazer
    71 4x4 CST Blazer
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>My Pics</a>
  14. beater74
    May 29, 2001
    1,749
    atlanta
    i'll do somthin like dat but on the drivers side.thanks
  15. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Hey beater, if you didn't notice, my reply was to krebs. But thats ok. Anyhow the bracket kit doesn't matter if it is serp or v belt style. The brackets are the same but they won't work on your rig like you said, only because of how and where the later engines accessories are mounted. As for the compressor, either clutch will work on it serp or v belt. When i purchased my york from the wrecking yard it was a v belt but i changed the clutch to serp.
  16. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Hey 4x4high...
    what's in the pvc pipe?
  17. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Hey reddog, what are you talking about?
  18. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    Hey, im pullin another compressor sunday. if n e one wants it, ill give it to ya for around $10-$20(w/e i end up payn for it.)
    If u want it, it'll be here.
    NITRO
  19. txbartman
    Jun 1, 2001
    1,975
    Plano, TX
    dibs
    Brian
  20. txguy
    txguy 1/2 ton status
    Sep 4, 2001
    114
    Round Rock (Austin) Tx
    Nitro! I will take one too!
