york fitting
Discussion in 'The Garage' started by 69K5, Oct 7, 2003.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    where do you get or what size are the two fittings on top of the york. the input and out put. they look like standard threads. i really dont want to haul it to home depot and try em all. something 5/8-3/4 i think.
    thanks
    69k5
  2. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    Look at www.onboardair.com, I think they say the sizes on there. I hope that helps.
    I need to clean mine up and get it mounted so any info you have on your install would be helpful. /forums/images/graemlins/thumb.gif
  3. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    Those are Flare fittings,probably 3/8-1/2 .that would be actual size of the tube and not thread size
  4. got_mud
    got_mud 1/2 ton status
    May 9, 2003
    316
    Wichita, KS
    thanks
    69k5
    go to your local auto parts house and have them convert Four Seasons part number 12908 to whatever they stock for size 8 a/c line or 12910 for size 10 a/c line. if you are working on a unit with a large diameter male threaded tube sticking up vertically from the compressor head plate, that is a tube-o fitting and the flange itself can be replaced with either of the numbers above. the flange fittings in the picture are for size 8 a/c line. fyi- they are not threaded, they are ribbed for a/c line 'push on and crimp' fittings. if they give you any crap, just tell them its on page 361 of the 2002 A/C & HEATER PARTS ILLUSTRATED catalog. the compressors are on page 157 and clutches on 57.
  5. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    [quote
    man that is awesome!! /forums/images/graemlins/thumb.gifwhere else can you get info like that! part numbers and page numbers! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    i will go check it out tommorow. mine are the threaded kind so i will pick those up.
    Sf87k5
    i am still getting all my parts together for the install. as soon as i have it all together i will put it in and post pics up. i have to get my mount made.
    thanks for the help
    69k5 /forums/images/graemlins/k5.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You have the flair fitting lines from the looks of it...
    You shouldn't have to do anything to them. Just use some good hi temp hose and 2 clamps.
    I have the threaded type and just crammed a 5/8 pipe thread (not sure on the size...yes I put a tapered thread on a strait thread /forums/images/graemlins/crazy.gif). I just put some pipe tape on there and jammed a brass female reducer on there!...of course I haven't put the stupid thing on the motor yet so who knows but I don't think it will leak.
  7. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i haver the threaded type. i just borrowed the pic from a website for a point of refrence. hopefully yours wont leak.
