York installed on it's side?
Discussion in 'The Garage' started by LKJR, May 21, 2003.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
  2. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    Re: York installed on it\'s side?
    It's not a problem with A/C. The problem with mounting a York on it's side with OBA is that it pumps a lot of oil out the discharge.
    Brett
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> You can mount them on their side for OBA as well, the oil level needs to be adjusted and you want the dicharge on the bottom, contrary to all logic. </font>
  4. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    Saw this in the junkyard on a blazer. They were using it for AC.
  5. DSJ
    DSJ Registered Member
    Mar 21, 2003
    33
    Reno NV
    I just pulled the high cap. one out at the junk yard, and it was on its side. So should it stay on its side or should I stand it up? I havent looked inside to see if there is a oil pick up or not.
