York OBA ?????????????'s
Discussion in 'The Garage' started by 1-tonmudder, Jun 1, 2006.
  1. 1-tonmudder
    1-tonmudder 1/2 ton status
    Apr 24, 2005
    3,052
    In a junkyard somewhere
    I have a York and the bracketry from a 70's chevy van on my CUCV that I am going to use for my OBA.I know alot of you guy's are running simillar set-up's,so how do you guy's have them plumbed and where did you get your parts.I have a holding tank from a dumptruck that I am going to mount under it.Kilby has all of the stuff to plumb it,but if I can save a little here I can spend it somewhere else.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    You can save more than a little..look around before you commit to buying from Kilby. Nothing wrong with any of his stuff. In fact, it is all top notch, which is rarely required.
    The only thing you really can't or shouldn't cheap out on is the safety devices like blowoff valves, and the outlet hose from the york. It gets real hot.
  3. 1-tonmudder
    Apr 24, 2005
    3,052
    I am going to use a rubber line that is steel braided inside simillar to what you see on heavy equip for the outlet.Yeah I'll probably get my check,and pop off valves from Kilby.
  4. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    I got my check valve, blow off valve and braided steel/teflon hose from McMaster Carr, i think i paid maybe $40 for the valves and a 12" and 18" hose. Then i got a presure switch for an air suspension system for @ $25 on line. I think it was this one http://www.truckspring.com/100-150-psi-pressure-switch-9193.html. Works great only problem i have is teh cheap air hose i used to run back to the tank doesn't like teh heat from the exhaust pipes too much.
  5. 1-tonmudder
    Apr 24, 2005
    3,052
    The truck I got the tank off of had plastic/teflon hoses running to it,so Ill probably use some of it.
