York Question
Discussion in 'The Garage' started by mikey_d05, Nov 20, 2006.
  1. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    I'm in the process of planning out the rear of my truggy thing. A 5 gallon tank is as tall as the fuel cell I plan on, so I see no harm in running one.
    However, based on 10 or so consecutive educated guesses, a york at idle would take 4-5 minutes to fill it to 120 PSI. Call me a picky bastard but that's too slow.
    Everyone with a york, if you would, post up your air tank size and how long it takes to go from 0-pressure. I'll run a 2.5 gallon if the 5'er takes too long but there will be almost no space saved by running the smaller tank.
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Mine will fill a 6 gal tank to 120psi in under a minute. It fills the tank to 125 psi in under 20 seconds at 2000 RPM. If I put a brick on the pedal, I can run a die grinder. I have a serp setup with a Kilby overdrive pulley.
  3. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    Mine is 13 gallon and it take's 3-4 mins to fill to 130#'s at idle 700 rpm.
  4. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    at idle it fills my 5 gallon tank in under a minute. With the high idle kicker on (1400 rpm) it takes between 10-20 seconds.
  5. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    Thanks guys, I knew I must have missed something in the calcs somewhere. I'll either get a 5 gallon from e-bay or a 6.3 gallon from surplus center.
  6. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    You guys running a york from a volvo or a ford one?
  7. cbbr
    Jul 17, 2004
    14,681
    Mine is from a ford.
  8. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    Mine is the ford as well. There is one other thing to consider though. On my rig the 5 gallon tank works, but 1st chance I get I will be changing it out for a larger tank or combine 2 5's. Just not enough storage for me.
  9. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    i run a 2.5 gallon. i would not waste to space that a 5 gallon tank takes up.
  10. 85-m1028
    85-m1028 1/2 ton status
    Apr 26, 2005
    485
    costa mesa california
    If your worried about fill time, why not just turn it on and fill the tank before you need to use it? I dont think it would hurt to run a pressurized tank?
  11. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    I think I'm gonna pick up a 6.3 gallon from surplus center. Pretty much the perfect dimensions for what I need.
    beater74: I said it before, a 2.5 gallon will save me nearly no space. The fuel cell is as tall or taller than the the 5 gallon, and the air tank will sit right in front of it lying down. Running a 2.5 would get me 3" of room height-wise and nothing else. That's not enough for me to consider running a tank with 1/2 the capacity.
  12. cbbr
    Jul 17, 2004
    14,681
    I would definately get the larger tank.
  13. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    What style of yorks are you guys running, I read that there are 3 kinds (stroke length difference or something like that)? Does it make a big difference because the ones you see on ebay you cant really tell from the pics which is which?
  14. mikey_d05
    Nov 23, 2004
    10,453
    Minnesota
    There are a couple of tricks to tell what size they are. The most definite is the edge on the front of the crankshaft. There should be a diagram in the tech section here showing what's what.
    I've got two 10ci Yorks on the bench. One good, one non-op sold to me by a deadbeat assclown. Works for a mock up that I don't care about dropping though. :D
  15. JEBSR
    Dec 23, 2004
    1,541
    Clarksville, TN
    Running the 10 as well.
