York wiring & resorvior question, no luck in ck5 search....
Discussion in 'The Garage' started by uglychevyZZ4, Aug 26, 2002.
  1. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    ive tried search and the york writeup..
    my york has only one wire and the writeup / diagram dont even show what it is, hot or cold, or switched to what?i dunno what has to get fire to engage the clutch for air build up??, im a big wiring dummy too, that dont help /forums/images/icons/laugh.gif /forums/images/icons/laugh.gif
    any input on this? and how often does the resorvior have to be filled too? /forums/images/icons/grin.gif
  2. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    that wire is for the clutch, just add 12v to it while the belt is turning a whala air /forums/images/icons/grin.gif
  3. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    If you have a one wire clutch, that's the hot one. It must be grounded at the case. I'd recommend using diode in the clutch circuit to spend the unduced voltage when you shut it off. Otherwise you will arc across the relay or switch.
    wire it like this:
    clutch wire|<- ground.
    This will use up the spike. Get it at radio shack.
  4. BigBadCad
    BigBadCad 1/2 ton status
    Dec 18, 2001
    109
    minneapolis, mn
    the single wire hooks up to a 12v(hot)switch(or set it up with a relay). The oil resevior has to have 1" of oil in the bottom. Bend a peice of bent wire to check the level.
  5. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    thanks ya'll, and welcome to ck-5 jeffro /forums/images/icons/laugh.gif either one of you know anything about using a relay? /forums/images/icons/confused.gif remember im the wiring dummy /forums/images/icons/grin.gif and Id like this wired for longevity, and safety /forums/images/icons/laugh.gif
  6. jeffro
    Jul 2, 2002
    406
    Scurry, TX
    I emailed you a diagram I whooped up.
  7. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    i gotr it thanks, but i dont know what the symbols mean /forums/images/icons/confused.gif remember, im the wiring diagram idiot /forums/images/icons/grin.gif
  8. jeffro
    Jul 2, 2002
    406
    Scurry, TX
    the only things not labeled are the grounds (upside-down trees) and the diode. Get the guy you buy it from to illustrate. I'm not sure how to explain it without hand gestures.
  9. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    no wonder y my york was puttin oil in the air lines (note to self...dont let oil overflow out of resorvoir)
    NITRO
  10. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> For those that aren't aware, there is a fix to cure the blow by in a York. You can see how to do it here. </font color>
  11. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    Where does he get those wonderfull links /forums/images/icons/laugh.gif Ok folks, i dont need an oil fix though, i need to know wtf is a diode, why i need it, and why not just a fuse, and a switch? /forums/images/icons/confused.gif
  12. jeffro
    Jul 2, 2002
    406
    Scurry, TX
    A diode is required because the coil on the clutch acts like an ignition coil. When you charge it up(turn it on) and shut it off the induced voltage must go somewhere. Switches and relay points make poor spark plugs and will fail prematurely. Ask the guy at radio shack what kind of diode you need and how to mount it. A diode acts like a check valve for electrons. A blocking diode will only allow current to pass one way.
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    a diode is an electrical one way valve
  14. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    so do i just put it inline as if it were a fusible link so it is an arch beetween the 12v+ and the york wire?
  15. jeffro
    Jul 2, 2002
    406
    Scurry, TX
    Negative. You wire it between the hot clutch wire and the chassis ground with the little arrow pointed toward the hot wire.
  16. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    as stated before, it has 1 wire and 1 wire only, there isnt a +/- just a + wire.
  17. beater74
    May 29, 2001
    1,749
    atlanta
    [/ QUOTE ] HUUUU /forums/images/icons/crazy.gif i don't get it on my setup my yorks grounded by attaching it to the block.
  18. jeffro
    Jul 2, 2002
    406
    Scurry, TX
    That is why the diode goes between the hot wire and the CHASSIS ground! Hire a GEEK to put it on!!
