  1. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    I have seen a few on Heeps and saw them mounted on there side with the top facing the passenger side ...Can we mount the yorks on there side for OBA and not have any issues ...
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    No, if you mount it on its side you will get oil in the air line. There is supposedly a fix for this but I have heard that then the seals let go.
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Actually, according to the York service manual they can be mounted straight up, at 45 or 90 degrees without a problem. However, contrary to what seems obvious (at least to me), you want the output on the bottom rather than the top. They come with left or right outputs so you need to make sure you get the right one for the orientation that you want.
    Here's a manual for a York clone made by CCI, these are supposed to be identical to the old Yorks.
    http://www.ccicompressor.com/docs/CCIsrvice.pdf
