you gotta be kidding me!
Discussion in 'The Garage' started by little79k5, Aug 19, 2002.
  1. little79k5
    little79k5 1/2 ton status
    Mar 27, 2002
    230
    panama city, fl
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    "Blocks are brand new, and are polished aluminum"
    They look like concrete.. and not polished!
  3. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,068
    479
    Grand Rapids area
    So where do you get U-bolts for these things? You must also need a centering pin, since these blocks obviously don't have one sticking out. A block that tall really needs a taper at each end to keep the rear wheels centered in the wheelwell. The top taper would match the angle of your springs at the mounting pin, to keep the block running straight up and down. The bottom taper would set the pinion angle.
    The only thing that is worse than these is two pairs of 4" blocks, stacked, which I have seen /forums/images/icons/crazy.gif
    What are they using for aluminum polish, gravel? /forums/images/icons/laugh.gif
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    That's the biggest block's I've seen. /forums/images/icons/shocked.gif
  5. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Holy Smokes:
    8" of lift ..... just don't take it out of the driveway!!!
    /forums/images/icons/shocked.gif /forums/images/icons/shocked.gif /forums/images/icons/shocked.gif /forums/images/icons/shocked.gif /forums/images/icons/shocked.gif /forums/images/icons/shocked.gif
  6. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    Sweeeet!!!!! Can I get a set for the front too?!! /forums/images/icons/tongue.gif
  7. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Still no bids /forums/images/icons/tongue.gif
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Let's see....
    ...get some 12" Superlift front springs, 8" rear Superlift springs, these 8" blocks for the rear, and lower the spring mounts on the front 4 more inches and have a total of 16" of suspension lift. /forums/images/icons/wink.gif
    Then get a 3" body lift and 19" total lift to install some 46" Firestone Field & Turf tires. /forums/images/icons/wink.gif /forums/images/icons/cool.gif /forums/images/icons/tongue.gif
  9. Clay's 72K5
    Clay's 72K5 Guest
    Could be worse, there's a guy who used to run around here with an old Land Cruiser who had hockey pucks for his lift. Talk about scary!
