You guys are probably going to hate me for even asking about this...
Discussion in 'The Garage' started by C10Jon, Oct 27, 2002.
  1. C10Jon
    C10Jon Registered Member
    Oct 27, 2002
    12
    BFE, OK
    I just bought my rig, a 72 Chevy C-10 for $100. It looks like crap, but after putting the timing chain back on it, it runs like a champ. Anyways, I need atleast 6" of lift by next Sunday for a run. Me and my friends have a $50 budget for lifting the beast. Unfortuately, I cant find any DPA's around here. I know this sounds like a crazy idea, but one of my friends came up with the idea of using some iron pipe with the exact same inside diameter as the outside diameter of the output shaft on the steering box, and welding it to the top of the original pitman arm. What do guys(and maybe gals) think? Would it last?
    Oh, and I like the "Graemlins" you guys have on this board! /forums/images/graemlins/truck.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/1zhelp.gif
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Hell noooooooo, don't do that!!!! Keep the drag link in a bind. Think of the worst case scenrio, weld breaks, you don't have steering, freeway, 75mph......... /forums/images/graemlins/frown.gif 6 inches of lift and a stock pitman arm wouldn't have a critical impact over a short period til you found the right one you need. Not trying to trash you or anything. I' would've done the same thing years ago. /forums/images/graemlins/blush.gif /forums/images/graemlins/crazy.gif
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    DO NOT DO THAT !!!!!!!!!
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Sounds sucidal to me. There are 2 places to NEVER skimp on any vehicle. Steering and brakes. Failure of either could result in your death.
    Is this truck a 2WD? A C10 is 2WD, while a K10 is 4WD. If it is a 4WD then you can buy a new steering arm that has 4 inches of rise built into it for about $60. You might even find a used one for less. /forums/images/graemlins/cool.gif While not perfect, it would be good enough to at least let you drive the truck.
  5. landsmasher
    landsmasher 1/2 ton status
    Mar 13, 2002
    4,423
    California, The Blow Me State
    I think you need a bigger budget... Or is this some kind of junkyard war thing with a maximum spending limit?
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    a 3" body lift is all you can do with that kind of jack.
    and your pals might have it out for you if they are suggesting this kind of mod, i wouldn't drink anything they handed me for a while /forums/images/graemlins/wink.gif
  7. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    Hell why not. and while your at it just put some 6" blocks front and rear to get your lift. You could make them out of wood and really save yourself some cash.
    You'll need to save all the money you can for your casket. /forums/images/graemlins/angryfire.gif
  8. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Since we know nothing about you and you have a 2wd truck. I'll get right to the point. DO IT, THATS THE BEST IDEA EVER! Then take some pictures of it so we have something to show what NOT to do. sheesh! /forums/images/graemlins/1zhelp.gif
    Why don't you fill in your profile if your going to stick around, and get some common sence.
  9. C10Jon
    Oct 27, 2002
    12
    BFE, OK
    It says C-10 on both front fenders, but it has a transfer case mated to the transmission, a driveshaft running to the front, and a solid front axle. We have driven it around in the mud, and all four tires sling mud, so it is a 4WD. Maybe they put C10 fenders on it. Were going to the salvage yard today to look on some heavy duty Chevies for DPA's. If all else fails, were going to weld some skid plates to the bottom of it. Maybe a dropped draglink would work?
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Since it's 4WD, then it's really a K10. Sounds like someone swapped out the front clip on it. C was Chevy's deignation for 2WD trucks, and K was for 4WD. While you're at the yard, look for lifted trucks. One of them may have a raised steering arm on it that you can snag cheap. The stock arm curves down towards the axle housing, while the raised ones curve up and away from it. /forums/images/graemlins/cool.gif They can be a real bear to remove, but it'll do what you need. /forums/images/graemlins/cool.gif
  11. 88k5blaza
    88k5blaza Registered Member
    Oct 17, 2002
    70
    new hampshire
    Re: You guys are probably going to me for even asking about this...
    just take a few hockey pucks and use them for the lift and definately try and find the right pitmon arm and stuff for the steering
  12. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    hockey pucks??? /forums/images/graemlins/confused.gif
  13. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> He must mean to use the hockey pucks for a body lift, and that's a bad idea too. They'll most likely split pretty quickly. Not like a regular body lift isn't dirt cheap anyways.</font color>
  14. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    obviously you need a steering arm such as this one. It can be fabbed at home for little or no money and looks great!
    http://128.83.80.200/taco/scary6.jpg
    As the following pics prove, you can be really creative when you set your mind to it!
    http://128.83.80.200/taco/scary2.jpg
    home.earthlink.net/~riverbeast/steering_files/image020.jpg
    http://home.earthlink.net/~riverbeast/steering_files/image004.jpg
    http://www.pirate4x4.com/forum/attachment.php?s=&amp;postid=904602
    OR...you could just take out that gun and shoot yourself right now. Don't be a moron and skimp on safety...Take some physics and design classes and find out why things are done the way they are! /forums/images/graemlins/eek.gif
  15. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
  16. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Notice how they paint everything yellow so you can see the dangerous parts easier. /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/ignore.gif
  17. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    I think that this is the setup that Daryl and his brother Daryl made for their truck:
    YEEEEE HAAAAAAA!
  18. Rasberry
    Rasberry 1/2 ton status
    Mar 30, 2001
    205
    Orlando, Fl
    Here's your Sign!
  19. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    I've seen hockey pucks used in place of lift blocks! Saw a truck once with like 6 stacked up. Don't remember if it was in the rear or the front though- probably both!
