you guys rule!!!!!!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by clintsk5, Mar 8, 2000.
  1. clintsk5
    clintsk5 1/2 ton status
    Mar 2, 2000
    288
    Kingman, Az.
    Thanks to all who put there cents in to my inquire!!!! Never thought I would get that much input!! Can anyone help???...OK...the gas gauge?....does it suppose to get 90 ohms full or empty?..The reason I ask...is that i heard it was 90 full...but when I put the wire ( straight off the sending unit ) to ground it reads " empty "...any other time it reads " full ".. Thanx again...
  2. BlueKnight
    BlueKnight 1/2 ton status
    Mar 6, 2000
    1,518
    Oregon
    wow I could use information on this to. My gas gauge one day decided to peg ast the full mark and thats it. It will drop to E when im aaaccckkkk cough wheeeeeeeze on the side of the road and walking for gas.
  3. clintsk5
    Mar 2, 2000
    288
    Kingman, Az.
    this one will not move up or down...ig I pull the dash on push it down it will go right back up...but wiil not drop even when I turn off the ignition!!!
  4. 6.2 man
    6.2 man 1/2 ton status Premium Member
    636
    Curtis , WA
    I hope this helps . With GM gauges they use some kind of resister for their gauges . Putting it directly to ground sometimes this isn't a true test . I think if you use a volt gauge on the hot wire you should see a fluctution in volts .Also a good ground is important for these to work . If there is no good ground tank will read full and stay there.
  5. Corey-88K5
    Corey-88K5 1/2 ton status
    720
    Home: Michigan, Stationed: Hill AFB (Home of Moab.
    If I recall correctly, when the ground is disconnected, the tank will read full. No power just the opposite.
    COrey
    88K5
    [​IMG]<font color=blue>Girls Like Guys In Bow Ties</font color=blue>
    <font color=red>http://www.geocities.com/corey_perez
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    I know that for the '69 - '72 Blazers, 10 ohms is empty, 90 ohms is full. Therefore, an open circuit on the sender wire, or a bad ground to the guage or sending unit will make the gauge go past full. A sender wire shorted to ground will make the gauge read empty. A bad sender could fail either way. I think the circuit is the same on the later model trucks / Blazers.
    Tim
    1970 Blazer CST 4X4 350 SM465 NP205
    1987 Suburban 4X4 350
    1988 Chevy Pickup 4X4 350
  7. clintsk5
    Mar 2, 2000
    288
    Kingman, Az.
    Thanx...I'll keep trying!
  8. cityfarmer2
    cityfarmer2 Guest
    I just replaced all gages with auto meter phatoms soon as I can I'll send out a couple of pics. Have not had any problems other than a loose speedo cable. My bag...Gary
