You guys with Yorks for on board air, question UPDATE
Discussion in 'The Garage' started by cybrfire, Sep 28, 2004.
  1. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    Is the fill port for the oil on the side of the pump? Or actually there is a bolt on each side. Also what type oil should be in there.
    Thanks.
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Re: You guys with Yorks for on board air, question
    You can fill from either side. There's some good info here... web page
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I put motor oil in mine. The things are tough little guys.
  4. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    FWP, thanks for the link. There is some good info on that page.
    Sandman, you running like a straight 30 weight?
    Here's a few progress pics.
    Got to make a stiffener bracket, belt tensioner and drill a hole for the service plug. Clean up and paint. Then on to mounting this.
    The one photo you can see the dual outputs. One will provide electrical for the jimmy while the other will be an output for the onboard welder. If I can manage to wire it all up. In theory it should work. By the way the paint can is there for size reference.
    You guys will have to excuse the blurry photos. Too much coffee this morning.
  5. BigBadCad
    BigBadCad 1/2 ton status
    Dec 18, 2001
    109
    minneapolis, mn
    I'm glad to see there's someone else out there who has taken the initiative to install OBA on a 500 caddy. Although I had the pleasure /forums/images/graemlins/rolleyes.gif of figuring out the fabwork with the engine sitting between the fenders.
  6. 77crewcab
    77crewcab 1/2 ton status
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Stupid question, but why did you tilt the york? It appears to have fit pretty well sitting strait up. Just curious?
  7. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    He's just showing it like that with the belt off
  8. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I believe its just on a hinge so that he can put a tensioner on it and then the belt will stay tight all the time. You see it leaning all the wya because it has nothing to stop it from going that far... Thats my theory anyway. /forums/images/graemlins/thumb.gif
  9. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    Rustbucket is on the money here. The tensioner will like a miniature tie rod with small heims on both ends. Instead of sticking a pry bar to tension it you just turn the sleeve and lock down the jam nuts when its tight. So when you tighten the belt it tilts over.
    BigBadCad, Did you put the york on that side of the motor?
  10. BigBadCad
    Dec 18, 2001
    109
    minneapolis, mn
    Yes I installed the york on that side of the motor in almost the same location. My alternator is located directly below the York. You'll end up doing some trimming on the upper potion of the fan shroud to get the belts to clear (at least I had to). I fabricated a flat mounting plate with a 3/8th's milled slot for belt tensioning to allow the York to be mounted flat. I have pictures but I need to recover them from a corrupt hard drive and my truck is presently 1300 miles away (for another month).
    Are you planning on running with a serpentine belt?
  11. 77crewcab
    Feb 9, 2004
    1,620
    Lubbock, Texas
    Okay that makes sense. Are you planning to start selling some brackets for the cad swap? I am thinking of doing this swap and planning to have york, a/c, p/s, alt and was trying to figure out how to maount every thing.
  12. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    i run marvel mystery oil in mine
  13. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    Never really thought about a production run on them. Probably not enough demand. Next summer I will be set up where I can make "one offs" for people without having the expense that I do now for smaller runs.
  14. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    [/ QUOTE ] No sweat. Here's a mod I recommend...(you'll still get some oil out of it, but not as much.) Oil fix
    Oil in the air is good for the air tools, which I need more often than straight air. I use a coalescent filter at the end of my air hose when I need to air up tires. HTH
  15. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    This oil fix is reported to be easier and works better:
    oil fix
    I still need to modify mine...
    I run straight 30W in mine.
  16. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yes, the oil fill ports are on each side. Just use standard 30W. I'm using 10w-30 cause thats what I run in my 350.
