You Might Be A Redneck Geek If...
Discussion in 'The Lounge' started by dremu, Nov 4, 2004.
  1. dremu
    Feb 27, 2000
    15,963
    454
    East of San Francisco
    your computers have Bondo on them /forums/images/graemlins/histerical.gif
    I'm building a RAID box based on a Mini-ITX motherboard ... basically, it's the size of four CD-ROM drives, but has six 250GB drives, and a whole 1GHz PC built in.
    The Bondo is covering up a hole for a floppy drive. Yes, it'll get sanded and painted... I got impatient and took a pic whilst it dries /forums/images/graemlins/laugh.gif
    So I think I'll be okay for space for a while... gonna start ripping my DVD's, but my 200GB of MP3's won't make much of a dent in it:
  2. boz42
    boz42 1/2 ton status GMOTM Winner
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    that is impresive
    to bad i don't know what it means? what does tb stand for i guess it means a [censored] load of memory
  3. thezentree
    thezentree 3/4 ton status
    Sep 19, 2003
    7,198
    NC
    it means his computer can kick your computer's ass. even if it is uglier /forums/images/graemlins/histerical.gif
  4. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
    /forums/images/graemlins/woot.gif
  5. dremu
    Feb 27, 2000
    15,963
    454
    TB = terabyte, i.e. 1024 gigabytes.
    It's 1,160GB, or 1,187,840MB (give or take /forums/images/graemlins/histerical.gif)
    It sounds crazy, but when a freakin' DVD takes over 4GB *per each disc*, and I wanna be able to record a coupla hundred, that space gets eaten up awful fast.
    -- A
  6. boz42
    Jun 3, 2003
    3,181
    Hopewell, Tn 38058
    prolly so, my puter isn't very tough
  7. dremu
    Feb 27, 2000
    15,963
    454
    I resemble that!
    Well, it'll look better once I paint it (Rustoleum textured black /forums/images/graemlins/woot.gif) and AMAZING, put the cover on.
    -- A
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Oh damn, that's cool. /forums/images/graemlins/waytogo.gif
  9. thezentree
    Sep 19, 2003
    7,198
    NC
    thats gonna be cool. if i had a desktop, i'd rice the hell outta the case /forums/images/graemlins/whistling.gif
    can you say racing stripes, LEDs, and a Type-R decal? /forums/images/graemlins/histerical.gif
  10. Skigirl
    Skigirl 1/2 ton status
    Apr 2, 2001
    2,563
    Los Angeles, California
    So did you buy a 1.3tb drive or somehow have those 250gig drives appear as one drive?
    If you bought (or acquired) a 1 tb drive, does it cost more or less than a house in Silicon Valley?
    And seriously, if it's 1 drive, isn't the access time excessive? If not, why not?
  11. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    He has 5 drives each on being 250GB. They are combined, probably through software, to look like one large drive. I'm also assuming that he's using a RAID 5 configuration which would be the best compromise of speed, drive space and redundancy. If I'm correct with my assumptions then if one of his drives happens to go bad it can be pulled out and replaced with another drive and the data can be restored on that drive. The problem with software RAID is that it uses up a lot of CPU power. The reason the access time isn't excessive is because it stripes the data across all the drives. i.e. a small piece of data on the first drive, the next small chunck of data on the second drive and so on. That way each drive has time to get to the next spot it needs to be and is transparent to the user.
    I'm using a hardware RAID controller and I've got 250GB hooked up to it now and just about out of space. I need to add more drives pretty soon. All my drives are either 36 or 73GB but I've got enough to add up to 1TB. /forums/images/graemlins/thumb.gif
  12. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    RAID is awesome. Next computer I build I will do a RAID 0 data-striping setup. I had originally thought about going SCSI, but I think RAID 0 will do just as well for what I use it for and be much cheaper. /forums/images/graemlins/thumb.gif
  13. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    I would highly recommend RAID 5 instead of R0. You're not losing that much space with R5 and you gain data redundancy. The more drives you have the less space you'd be losing.
  14. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I'm not looking for redundancy, I'm looking for speed. Will a R5 give the speed increase that a R0 setup will?
  15. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    Depends on if you're doing a read or a write, but there are other factors also. When you do a write with a R5 a calculation needs to be done for the parity so that slows it down a little. It sounds like your going to be using software raid also. Is this for a video server?
  16. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    What is your processer speed and bus speed?????????????
  17. dremu
    Feb 27, 2000
    15,963
    454
    Six 250's, actually. Biggest single drive I've seen is a 400 at the moment.
    -- A
  18. dremu
    Feb 27, 2000
    15,963
    454
    Oh, well, this one is not spectacular there. It's a Mini-ITX board from VIA; this one is a 1GHz Nehemiah.
    The reason I'm using it is that the motherboard is TINY -- it's 6 3/4" square and has video, NIC, IDE, *everything* built in. Cheap and crazy low heat / low power, they're great for applications where size is more important than computing horsepower.
    Umm, all kinds o' crazy stuff on the fan page.
    -- A
  19. dremu
    Feb 27, 2000
    15,963
    454
    Yeah. I had hardware RAID before (Adaptec 2400 controllers) but I was limited to four drives per array, plus the cards are big (and not cheap!)
    This one I'm doing software RAID, so I can do all six drives on one array ... but I take a MAJOR performance hit on writes. I'm mostly doing reading, though (it's a file server), and I wanted small, and cheap. Remember, the *whole computer* fits inside the drive enclosure, and takes less power (power bill! heat!) than, say, most high performance video cards alone. /forums/images/graemlins/eek.gif
    -- A
  20. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    Definitely Needs the Type R sticker.
