"You want to put it behind WHAT?!?"
Discussion in 'The Garage' started by big94gmc, Aug 27, 2006.
  1. big94gmc
    big94gmc 1/2 ton status
    Sep 1, 2004
    3,651
    No VA.
    Who makes an adapter, or, What would be required, to put an SM465 behind a 2.2 (from a '95 S10)????
    I'm serious about this....I've got some ideas rolling around.
  2. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    You'd need an adapter from a 60 degree v6 to a v8 pattern. I'm sure they are out there.
  3. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I think that would be a bada$$ setup for a little buggy or something of the sort. I think there is quite a bit of aftermarket supprt for the 2.2.
  4. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    2.2's suck.
    Just because there is an aftermarket (stupid J-body owners) doesnt mean that it's ok.
    But to each his own.
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    a truck 2.2 and a J or N body 2.2 are 2 different animals.
  6. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    I meant 2.4 that's in an s10.
    The ohv one.
  7. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    I was thinking something along the lines of a two seat go cart. 2.2 would be more than enough.
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    there never has been a 2.4 in an S10. 2.0, 2.2, 2.5, and the above mentioned 60* 2.8 V6
  9. big94gmc
    Sep 1, 2004
    3,651
    No VA.
    I'm thinking, with a doubler, torque would be sufficent enough.... And, the parts truck I just picked up (I drove it up on the trailer) has a running 2.2 in it. In liu of fabbing in a 350, at least at this stage in time, it would be easier to run a motor that the frame and truck are already set up for.
    So....if I did a 2.2/465/203/205 and 4.10's with 38's, I think it would be plenty torquey.
  10. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    <----- Confused easily
    Meant the only 4 cylinder available from 94 up....
  11. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    yeah, the 2.2.
    i would probably shy away from the 4.10s though.
  12. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    In an s-10 torque will be in abundance with that setup.
  13. Teamstatic2001
    Teamstatic2001 Registered Member
    Dec 24, 2005
    92
    Muskegon, MI
    Most all 2.2 s10s if not all had 4.10s stock. 2.2s are not bad engines you can beat the hell out of them and there is headers and storkers and turbos and all kind or stuff to do to them, 2.3 quad 4 TB swap is common they are bigger and fit right. Same internals as the 2.2 cavi engines so there alot of aftermarket internals from the ricer demand.
  14. big94gmc
    Sep 1, 2004
    3,651
    No VA.
    But what about putting a 465 behind one???????
  15. ryan22re
    Feb 5, 2005
    3,368
    Irmo, SC
    Or, from what I understand Jeeps used the same bellhousing pattern as the 60 degree v6 which should be the same as the 2.2. There may be a jeep bellhousing out there that will literally bolt it. The pilot bushing and clutch however is a different story.
    Try calling advance or novak or the like. I'm sure it can be done.
  16. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    your joking right? a doubler with sm465 weighs about 450 lbs( not pausitive correct me if I'm wrong). I know you said your serious but I honestly think your wasting time and money. The throws on the sm465 aren't short at all...and with a doubler you'd probably never get over 15 mph if that. Now if your making a crawling buggy then I could see it but I saw the two words go and cart. Might want to think about 4.3 though if you want the sm465 because by the time that power gets the wheels with a 2.2 that thing will be a turd... won't move without being in low and won't move very fast in low. I know the sm465 has a low first and second but definetly not go cart material.
  17. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    The guy asking the "?" is not who said go cart.
    Plus, its no different than a 'yota w 22r + Marlin.
    big94, is said S10 an auto or stick right now? If it is a stick why not use one of the NP231 doublers behind that? That might be easier/faster and still get things good and low. Or is the S10's manual crap?
  18. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    He already owns a 465 with doubler combo from his old rig that got wrecked:D
    Ira
  19. beastofablaze
    Apr 4, 2005
    441
    CA
    oops maybe I should learn to read more carefully... yeah tru I've seen yota's with 2 tcase's running a 4 banger and they dominate in the rocks but rocks is about all they dominate.
  20. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Ah, that little tid-bit changes things. I thought he sold it all.
