Your humble opinion
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dmntd, Mar 14, 2005.
  1. dmntd
    dmntd Registered Member
    Sep 20, 2004
    9
    I am wanting to replace the quadrajet that is in my 85k5 350. I was thinking of a edelbrock 650 or 700 any input would be appreciated.
  2. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    I don't think many on here will tell you to do it. Apparently the e-brock performer carbs are awesome for a street driven vehicle, but have fuel delivery troubles on rough roads and steep grades. I have a performer 600 cfm on my K5 that came with it. The engine would die on washboard roads while I was coasting. I haven't had that problem since I installed the offroad kit, but I havent really done any steep climbs/descents, or gotten off camber with it. I'm looking to get a rebuildable q-jet set up for my motor, a gm crate 350. From what I've read on this site, a q-jet properly tuned for your particular engine is the best way to go, if you are carbe'd.
  3. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    Check out SMI Carbs.
    I ended up getting a rebuilt quadrajet from them. I'm still in process of putting a new motor in, so I can't tell you how it runs; but after all the research I did on a good carb, and after talking to Sean over at SMI, I purchased one of his stage 2 rochesters.
    Give him a call and tell him what you have for a motor and what you plan to use the truck for. He can build you a custom carb for your application.
    Thomas.
  4. dmntd
    Sep 20, 2004
    9
    Unfortunatly I don't know crap about carbs or fuel systems, but I am willing to work and screw up/learn. The current carb won't enguage 4bbl even if you use your hands and try it manualy. My K5 only sees the pavment not the dirt (for now anyway) and need an interm solution. I hate having that heavy beast with a 350 and only 2bbl working. I have heard quadrajets suck from some people I know but thought I would ask the experts here first. I still don't know what I want to do with this truck. One day I will figure that out :laugh:
  5. Stoopalini
    Oct 17, 2000
    999
    Austin, Texas
    Usually, people who say q-jets suck are those who tried to tune one and don't know how. The q-jet can be difficult to rebuild and tune yourself, but a properly built and tuned Q-jet will run awesome! Not only for off roading, but there are many a drag racer who run Q-jets because of the power making capabilities of them. They have relatively small primaries and large secondaries. This makes for decent gas milage when putting around, and good power when you need it.
    If you're looking for a quick cheap bolt on carb, you can probably find a better deal then a quality rebuilt Q-jet. But if you're looking for power, reliability, and off-road capability, I would definitely recommend a quadrajet.
    Thomas.
  6. dyeager535
    26,980
    So what exactly is wrong with the secondaries?
    Even with the engine roaring away in park/neutral, they aren't going to open. With the engine idling, you'll have a very hard time opening the secondary air valve also, since it is held shut with vacuum on a bunch of Q-jets. I suspect this is the "problem" you are experiencing.
    If you can't physically move the upper throttle blades, (air valve) or the lower ones when the engine is hot, then there is a problem that can probably be fixed pretty easily.
    I've never wired secondaries shut, but I suspect if you have non-functioning secondaries, you'd REALLY know it.
  7. MA87K5
    MA87K5 1/2 ton status
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    Try this for the secondaries. Loosen the 4 carb mounting bolts. The carb might be off centered. If it is and the secondaries open after wiggling the loose carb, then open the secondaries all the way and tighten the carb back down with the secondaries open. the secondaries are usually spring loaded. There is a small lever on the opposite side of the throttle lever that prevents the secondaries from opening when it is cold. Move the lever to open the secondaries. Hope this helps.
  8. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    As a matter of fact, there is a shop here locally that the old man has been rebuilding Q-Jets for 25+ years. A lot of the locals swear by him (not at him). $162 + tax. I pick mine up in the morning.
    John
  9. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    If you go with a rebuilt Q-Jet, then make damn sure that they re-bushing the primary throttle shaft (many re-builders do not do this). This is the number #1 problem with old, worn out Q-Jets (the primary throttle shafts wear out). I have seen people spend a lot of money on rebuilt Q-Jets, and then still have problems with vacuum leaks through the main throttle shaft, and not idling properly because the main throttle shaft is "cock-eyed" and hanging up.
  10. nau81blazer
    nau81blazer 1/2 ton status
    Mar 6, 2004
    329
    Cincinnati, OH
    I wouldn't go with an edelbrock. I have a performer right now and I experience most of the problems these other guys are talking about, plus some. I haven't really been happy with it since the day I got it, i'm just to poor to do anything about it:) .
    --Adam
  11. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    Love my Edelbrock on the road, hate it off road.
    -Chris
  12. aduff85k5
    aduff85k5 Registered Member
    Dec 31, 2004
    91
    florida panhandle
    just got a truck avenger carb from holley. now the engine runs like crap. gotta get the engine running up to par. the holley is good for 40 degree incline 30 degree declin and side manuvers.
  13. akbound
    akbound 1/2 ton status
    Apr 20, 2004
    San Antonio
    From what I remember (I loaned out my Haynes Rochester Manual), the secondaries only open under load. Therefore, if all is working well you should feel/hear them open.
    Quadrajets are the way to go and you don't have to pay $350 or more. Just get a rebuilt one. I have had really good luck with the ones from Autozone. The last one I got cost about $120 and I just bolted it on and the truck started right up. Slight mixture adjustment and it was good to go.
