Zerk in leaf spring ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ron, Jun 27, 2001.
  1. Ron
    Ron Registered Member
    Jun 9, 2001
    55
    Washington
    Can the leaf spring be tapped to install a zerk fitting to grease the leaf spring bushings? It would eliminate having to change the bolts to the greasable type if it will work. Any experience with this?Just an Idea. Thanks, Ron
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    The problem with that would be that the grease would go to only where the zerk goes on the inside - there are no channels to distribute it.
    I say just go greasable bolts so the grease goes on the inside where it needs to be. Plus, bolts are frequently reused. You don't know how long you'll keep the same front springs.
    -- Mike
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i would just buy the greasable ones
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>
  4. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    not to mention how hard it would be to drill the leaf spring itself and tap it. That steel is hardened and very tough to attack.
    Crawlin the rocks with my K5
    <A target="_blank" HREF=http://www.rockreadyk5.com>http://www.rockreadyk5.com</A>
  5. Ron
    Jun 9, 2001
    55
    Washington
    Thanks everyone the answer from Waxer was what I was looking for. Guess I will buy the bolts . Does anyone know where and how much these are?
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    you can get them from ord dont remember the price though but they have price's on there web site
