zero lift question
Discussion in 'OffRoad Design' started by 86 4door, Dec 10, 2002.
  1. 86 4door
    86 4door Registered Member
    Nov 28, 2002
    15
    pottstown PA
    I have a 1986 K30 crew cab, new 5.5" lift springs in front, i need another 2" of lift to clear my 38"16.5 radial"s at full turn. my question is is it safe to use your 1"ad a leaf block,in addition to two stock rear overload springs for a total of 2" of lift, will it be ok in your opinion,would this be safe.I already have a 3" body lift, and i dont want to cut the fenders
  2. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Have you thought of a different off-set rims... /forums/images/graemlins/ears.gif
  3. Stephen
    Sep 15, 2000
    4,228
    142
    Carbondale Colorado
    I wouldn't recommend doing anything more than the 1" of either the zero rates or the overload. You're adding a lot of leverage on the front end going with any more.
  4. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    longer shackles and zero rate combo?
  5. reddog64
    Nov 9, 2000
    3,325
    the longer shackles lift it a little bit...
    but also point the pinion down a few degrees.. not much though...
    I think that aside from getting a body lift, or larger lift springs... the shackle and ord 1 incher are your best bet... should be enough.. did you trim the fenders yet? /forums/images/graemlins/ears.gif
  6. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    just cut the fenders, they look better with some trimming anyway.
