zero rate add a leaf question
Discussion in 'The Garage' started by chubbynova, Dec 20, 2005.
  1. chubbynova
    chubbynova Registered Member
    Oct 26, 2005
    77
    Cypress Tx
    can i install ORD zero rate add a leafs and move my front axle forward an inch without having to change my factory steering? i am running a 4 in lift with 35s and rub alot. i plan on doing some fender triming soon but was wondering if these would help to minimize the amount i have to cut? thanks
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    If it rubs in the area near the footwell, yes, moving it forward will help. You will need to do more cutting up front because of it. The height of the zero rate may stop the rubbing on its own. My son ran 5" with 35s and so did I. Only rubbed on full stuff using a zero rate in the stock location.
  3. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    You can do this but you will have to adjust the drag link to re-center the steering. If you move the axle forward, you will have to shorten the draglink.
  4. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    I wouldn't move the axle foreward with factory push-pull steering. The links are short enough as it is, shortening it 1" would make a bad thing worse IMHO. If you're going for more clearance with the stock setup, how about just putting the zero rate in the center position until you can afford to get a cross steering setup?
  5. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    x2.
  6. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    Crap! I've never heard this concern before. Is this a big concern?
  7. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    Yes, it is. Shortening the drag link will decrease the amount of steering you have.
  8. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    What size wheels are you running? (15x8, 15x10, etc.) And how muc back spacing?
  9. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Huge concern..... Fixable with crossover steering.
