zero rate add a leaves and degree shims
Discussion in 'OffRoad Design' started by beater74, Mar 7, 2002.
  1. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    well as the title says can i use the add a leaves and some degree shims safely? thanks
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I asked a similar question a while back, and he said I could use degree shims with zero rates. He told me first to lower the tcase first to try and solve my vibration problem, then to use degree shims second. If you are going to use degree shims with the offset zero rates, that might be a totally different story though. Hope this helps.
    Harley
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The zero rates bolt in just like a leaf so you can treat them just like a leaf. So you can put the shim right under them and be fine. You can also sandwich the shim between the spring and zero rates to keep them captured better.
  4. beater74
    May 29, 2001
    1,749
    atlanta
    tanks, i'm gonna call you give ya a call next week with a big ol oder! the tax refund fairy visited me yesterday yeh!
  5. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    i should do my taxes...then i can pay off bills and move into my house with less debt
    Grant
  6. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I had degree blocks welded to the add a leafs. Counter sunk the bolt hole and everything. Added 3/8" net.
    Stephen - did that void my warranty? HAHAHAHA
  7. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Even after you ruined the solid steel blocks by welding to them (?) I think I'll replace them if you can break them. :-)
  8. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Yeah, they are causing my truck to drive like it has a loose nut (behind the wheel). /forums/images/icons/smile.gif
