zero rate and crossover?
Discussion in 'The Garage' started by nicotine, Jan 21, 2005.
  1. nicotine
    nicotine 1/2 ton status
    Jan 11, 2004
    116
    if i use a zero-rate to move my axle forward i wont have to change my cossmeber when i do crossover steering is this correct? also should i just change my crossmeber because i am doing a engine swap soon?
    also a little of subject but with the engine it is a 350 bored 60 over should this be a problem with building the engine up with more power?
  2. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    How much lift do you have? Are you using a straight or bent drag link? I have a 2 1/2" lift w/ ORD's bent draglink and have little issues with the drag link hitting the crossmember.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I run 4.5" lift with a bent draglink on my crossover and I BARELY rub the engine crossmember sometimes. It is not a big deal, and I didn't move my axle.
    As for using a zero rate to move it, you must remember that if you use a zero rate you will then have to use a spacer underneith your steering arm so the draglink will clear the spring pack on the passenger side.
    Harley
  4. nicotine
    Jan 11, 2004
    116
    i have 5 inches of lift and i am not sure if i want a bent or straight drag link? wich is better? and why? i am doing an engine swap soon and that would be the best time time to do this so all opions are welcome i need some info
  5. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Bent draglink with 5" lift should clear the engine crossmember. Mine barely touches with a 4.5" lift. Nothing a grinder wouldn't cure. The bent link is better since it stresses the TRE's less and puts them at a better operating angle.
    Harley
  6. nicotine
    Jan 11, 2004
    116
    if i do decide to use the zero rate were would you get a spacer so it clears the spring pack?
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    www.sky-manufacturing.com
    They sell the spacers, studs, steering arms, draglinks, etc, etc. There customer service is great and there prices are very competitive.
    Harley
  8. MountainMan
    MountainMan Registered Member
    Oct 9, 2000
    89
    Highlands Ranch, Colorado
    does someone have a picture of what crossover steering is, i am not clear on what is being crossed over...
    :confused: :blush:
  9. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Click on my link in my signature that says "My K5" there is pics of my crossover steering setup in one of the albums.
    Harley
  10. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    I have the ORD crossover with 12" springs & 1" zero rate pushing the front axle 1" forward. The drag link is also bent. I don't have any problems with the crossmember.
  11. MountainMan
    Oct 9, 2000
    89
    Sweet pics Hoss!
    So a crossover is changing the arm to go over the springs, i get it, thanks!
    Your pics of the flex test with all the blazers in the background makes me wanna go to a blazer fest right now!
