zero rate and driveshaft
Discussion in 'The Garage' started by RootBreaker, Apr 4, 2005.
  1. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    Ok so a zero rate gives you 1" lift and you can move the axle around.. if I move my axle forward 1" what can I expect the drive shaft to stretch? is it a % of that 1"?
    since I put those extra long (4" longer) shackles I know that my shocks bottom out before the driveshaft pops.... so I put the factory shackles back on thus lowering my truck 2" but going up 1" with zero rate...
    also I have the axle wedge under the front and with the axle moved forward 1" the wedge is not under the entire thing... is this safe? I may just put the zero rate in the middle so not moving the axle forward.... just wanted the 1" lift.....
    just curious...
    I just took the passenger side off and started but got dark and need to help the wife with the kids... got my 5 year old, 1.5 year old uncle to my son (dont ask long story), 2 cousins, 4 neighbors and she is trying to study for a college exam....
    got the carb adjusted perty nicely and got disc brakes adjusted and found out part of my problem... :crazy:
  2. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    When I had my zero rates on I couldn't figure out a way to put my front shims on so left them off. Moved my axle forward to the max with the zero rates and I didn't like the angle of the front pinion. Plus the drive shaft was nearly fully extended, I am rinning a 6" suspension, so in the end I pulled the zero rates and put the shims back on the axle. Eventually I will have the zero rates milled with about 6* in it and have the money to extend my front shaft about 4 inches or so and move the tcase back up next to the frame and put the spacers back where there supposed to be.
  3. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    lol... should i answer your posts here or on nj4wheel??
  4. RootBreaker
    Nov 29, 2001
    5,117
    173
    hey.. one has to do what one has....
    njfourwheelers.com doesnt get much traffic...
    thus my usual sites
    nj4whl
    ck5.com
    pavementsucks.com
    Peace!!!
