zero rate dimensions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigBadCad, Feb 27, 2003.
  1. BigBadCad
    BigBadCad 1/2 ton status
    Dec 18, 2001
    109
    minneapolis, mn
    What are the finished dimensions of the ORD Zero Rate's?
    1 X 3 X ? Also, what size hole do they have for bolting them to the spring pack? I'm planning on cutting up a few during lunch break at work tommorow.
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    The hole would be the diameter of the spring pin or whatever it is called.
    You should make them the width of your spring pack and the length of the spring perch. Also, radius the edges.
    -- Mike
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    The zero-rates measure 1 x 2.5 x 5, not 3" like you listed. GM springs are 2.5" wide, while Ford has 3" wide springs. /forums/images/graemlins/wink.gif
    Center pins for GM's are 3/8" bolts by however long you need to fit the block/pack combo together. /forums/images/graemlins/wink.gif
