Zero rate & front driveshaft?
Discussion in 'The Garage' started by WhiteBurb, Aug 28, 2005.
  1. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    I'm going to make a set of "zero rates" out of some old overload leafs I have. How long should they be? I was thinking long enough that the ends are just past the u-bolts.
    Also, is there supposed to be some sort of a seal on the front driveshaft slip joint? Whenever I lube it, all the grease comes out of the joint.
    Thanks again
  2. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    just past the u bolts is good, just make sure to but a center pin through the whole pack
    and there is a seal that goes on the slip yoke, you should be able to unscrew a thin stamped cap from the female side of the slip joint to see it
  3. WhiteBurb
    Mar 10, 2005
    307
    Louisiana
    Thanks.
