Zero Rate Install
Discussion in 'OffRoad Design' started by Mastiff, Feb 10, 2004.
  1. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    I think I asked about this a while back, but I can't find my old post with search... anyway, how does the install of the 1" zero rates go? I just want to get the extra height, not move front or back.
    I understand how to jack the spring away from the axle and all that, but I've never disassembled my spring pack. Do I try to hold it together with C-clamps before removing the center bolt? Is this possible while still leaving room for the zero rate? What do you do IF the leaves become separated?
    Thanks.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yes, you'll want to C-clamp the spring pack before you remove the old center pin
    You have to have enough room to remove the old center pin, then enough room to install the new center pin along with the zero rate
    Best and easiest way would be to completely remove the spring(s) from the vehicle, and stack them all back up and clamp them together so you can install the zero rate and center pin.
    Hold this helps ya out /forums/images/graemlins/waytogo.gif
  3. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    Thanks for the reply. You really think it's easiest to remove the springs? Man, what a PITA. /forums/images/graemlins/doah.gif I put the lift on this truck and I remember using my full vocabulary of four letter words before we managed to get everything put together. I'd sure lean towards keeping stuff together if it's possible.
    My rancho spring pack has a huge bottom leaf that might be a real good spot for a C-clamp.
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Its only easiest to remove the spring pack if the leafs come apart on you for ease of reassembly. But if the C-clamp holds fine, then all i did when I installed mine is move the axle forward just enought to get the pins in and out.
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Yup, what he said.
  6. CK5
    May 19, 1999
    21,623
    701
    CO
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Man steve, did you have to jump in the time machine to dig that one up? /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  8. Mastiff
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
