zero rate kit...is it a pair or what?
Discussion in 'OffRoad Design' started by bryguy00b, Jul 27, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    does the zero rate kit include a pair of blocks(meaning 2) i want to try some on all 4 corners of my truck for a little more clearence..so would i just order 2 kits..
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    yes, they are sold in pairs.
  3. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    What is the install like on these? I'm not sure what happens when I remove the center pin from my spring pack. Should I be able to just remove the U-bolts, jack the frame away from the axle, pull the center pin to add the new 1" leaf, then let it back down? Or is it a little tougher than that?
    I installed my lift kit a long time ago, but I remember I did just a little bit of cussing trying to get the spring eyes lined up. I'm kinda scared to take any of it apart.
    I'd also like to install the ORD greasable shackles and bushings all around, but the same fear is holding me back. /forums/images/graemlins/wink.gif
  4. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    Use a C-clamp to hold the spring pack together before you take the spring bolt out.
