zero rate offset??????s
Discussion in 'The Garage' started by rubbinz raczn, Jan 15, 2005.
  1. rubbinz raczn
    rubbinz raczn 1/2 ton status
    Oct 4, 2004
    656
    too far north!
    doing a 56" front spring swap and have a spare set of zero rates. i will be moving the front axle forward 2" with the swap. i don't need the lift,:confused: but will i benefit from moving the axle forward 1-1/2" more that the zero rate can give? or will this place too much leverage on the spring?
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    You will have a better approach angle... and I hope that you are gonna do crossover at the same time. Never done it, but from what I understand the push/pull steering doesn't like the axle being moved, or a flexy suspension!!
  3. rubbinz raczn
    Oct 4, 2004
    656
    too far north!
    yeah doing the crossover also! if i use the zero rate should i pull the overload off?
