Zero Rate Offset
Discussion in 'The Garage' started by btolenti, Oct 1, 2005.
  1. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    Does it matter how you bolt the zero rate to the spring pack when you are using the offset?
    Should I bolt the zero rate to the pack using the center hole, and use a small centering pin as the offset?
    Or should I bolt the zero rate to the pack using the offset hole, and use the small centering pin on the zero rate center hole????
    Does it matter???? :doah:
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Bolt the zero rate to the spring using the center recesed hole. Use the small center pin for the locating of the axle.
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    no no no, its small centerpin through the center hole at all times! you bolt to the springpack w/ the offset holes. this keeeps the entire zero rate on the axle perch at all times.
  4. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    Ok Now Im confused
  5. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    Just remember to have the short centerpin in the center of the zero rate. As long as the beveled edges ar up you have no choice to install it correctly (assuming you used the ORD 0Rate)
  6. BlitzK5
    Jul 29, 2005
    288
    Don't you just put the centre pin through the middle of the zero rate and then through the leaf springs hole.
  7. btolenti
    Sep 28, 2003
    644
    Gilroy, CA
    aha! That's why I was confused. I got mine from Black Widow Performance, and both sides of the zero rate are slightly beveled.
    79k20350 is right. You use the center hole for locating the axle and the offset holes to bolt the zero rate to the spring pack - you can see that by looking at the offroaddesign website. They will only work one way if you want the bevel towards the pack.
    Thanks guys! :waytogo:
