zero rate/ overloads
Discussion in 'The Garage' started by MNorby, Oct 17, 2006.
  1. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    Anyone every try or see a problem with countersinking and drilling new center pin hole sin some overload leaves to mimic the idea of the ORD zero rate for axle relocation? If a overload is roughly 3/4" thick and the head of a bolt roughly 1/4" then there would still be 1/2" of meterial between the bolt head and bottom. Criticism?
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    You would be removing material from the center of a spring. There is not enough material left to handle the flexing. Get a spring perch with some offset holes. Or just redrill yours.
  3. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    Unless you cut the overload down to the length of a zero rate, it would be pointless because the short side would touch the springs and the long side wouldnt... Cut down i see no problem.
    And overloads are REALLY FUN to cut down, takes awhile. They are very tough to drill.
  4. ryan22re
    ryan22re 1/2 ton status
    Feb 5, 2005
    3,368
    Irmo, SC
    Try finding a counter bore tool that would work in spring steel.
    Cheap is one thing, but I can get 1 x 2.5 x 6 in cold roll for about 10-12 bucks a pop from my steel supplier, cut to length. That's no company discount, just me calling on the phone and ordering.
  5. MNorby
    Dec 10, 2001
    6,127
    57
    Powell, Wy
    I have some 3" wide 1" thick strap on hand but don't think it will fit in band saw to trim down. Just had that concept pop into my head about overloads.
