Zero rate pic...
Discussion in 'The Garage' started by Confedneck79K30, Jan 21, 2007.
  1. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    anyone got a pic of their zero rates installed on the springs, out of the truck??
  2. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    I would also like to see some pics....
  3. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    im tryin to figger out how they work and bolt up and the website doesnt offer what i need to SEE....
  4. josh86k10
    josh86k10 1/2 ton status
    Feb 13, 2005
    423
    Knoxville, TN
    Not exactly what you asked for, but it may help.
  5. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    I had the same question a couple of months ago and there was a real good thread on it...but I can't remember the url:
  6. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    nope, thats if you`re using the zero rate to move the axle....
  7. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    thats the same thing tho, but instead of using 2 pins, you just use one big one
  8. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    So, what is the extra bolt for that comes with the zeros, for when you use the "offset" option, or???
  9. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    yea its only used when u want to use it to move the axle. i used to have the front offset, and the rear was just in stock location
  10. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Just using it as an add-a-leaf, it just bolts in like a regular leaf.
  11. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    cool, thanks for the info James:thumb:
  12. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    no problem man, keep building that rig;)
  13. Big Blzn
    Big Blzn 1/2 ton status GMOTM Winner
    Jan 30, 2006
    3,587
    Orange County, CA.
    I'll take pics tonight and post them later if you like. I havbe them on the front and rear.
  14. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    Yeah, they just bolt in like another leaf would.
    When you are taking the springs apart, be sure to use a c-clamp to hold them together. If you dont, your springs will separate when you take the center pin out. Once you have it out, throw the zero rate on the bottom, throw in the new center pin, tighten, and voila! Cake.
    -Harrison
  15. dieselponyexpress
    dieselponyexpress 1/2 ton status
    Jan 26, 2004
    220
    Germany
    So it all comes down to a lift block - a small one though.
    Did I miss something? :confused:
    Walter
  16. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    It`s not a lift block, it bolts directly to the leaves. Its not an AAL because it doesnt add anything to the rates. Its a Zero-Rate!:D
  17. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    still wanting a picture, i see the drawing, but i think that gives me the idea, a pic would help for sure when i slap some together
  18. Big Blzn
    Jan 30, 2006
    3,587
    Orange County, CA.
    You want pics of them installed without the axel bolted to them but this is what I have. Although, I put the shims between the zero rates and the leaf pack. Don't know if this is a problem but I did this because the shims I used are aluminum and I didn't think it would make much of a difference. What do you others think? No problems so far. Here are my pics.
  19. mrdrinksalil
    mrdrinksalil 1/2 ton status
    Apr 4, 2005
    1,595
    Atlanta, Georgia
    Ok, I'm confused. Prolly cause I can't look at the attached images. I just purchased zero rates as well and arn't really sure how to install them. I want to move the axle forward 1.5" so do I need to bolt the ZR on with the original hole, and then drill another one for the pin into the axle?
  20. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    the bolt with the rounded head always goes in the center hole with the rounded end at the bottom. if you plan on offsetting the axle, run that bolt through the center hole and tighten it down, cut it down level with the top of zero rate.
    now with the regular looking bolt, put it through one of the offset holes in the zero rate(nut on top). this is the bolt goes through the zero rate from the bottom and up through the hole in the leaf pack. slap the nut on there, tighten it down and you are good to go.
