zero rate question
Discussion in 'The Garage' started by bigbadchev84, Jun 1, 2006.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    is it possible to move the front axle forward with a zerorate and still safetly use the stock push-pull steering?
  2. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    personally i dont see why not... you just have to adjust the link..... forget the proper term... draglink?
  3. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    however far you move the axle forward is how far your have to shorten the draglink. if you have crappy steering now, it's only going to get worse as you shorten the draglink.
  4. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    anyone have 1st hand experience?
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    dont do it, youll regret it. The stock steering is bad enough and it will only get alot worse!
  6. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    well i can live with the push-pull, just wanted to know if it is functional at all? my truck just looks funny and needs the tires moved forward
  7. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I have zero rates with 4" BDS springs. I moved the axle an 1.5" forword. The steering is worse. I basically have no steering to the left. This is just a temp setup till I get a 60 and crossover.
  8. bigbadchev84
    May 17, 2004
    2,191
    Hermiston, Oregon
    allright thanks, i guess that is out of the question then
  9. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    The shortening of the arm means less turning ability. There is less to push and pull basicly.
  10. mostwanted
    mostwanted 1/2 ton status
    Feb 5, 2006
    765
    Kansas City, MO
    I asked this question in regards to 52's. Boy, did I feel flamed. My reasoning was that the 52 swap moves the axle forward 1.5". If I install the zero rate to move the axle 1.5" back, this should correct this problem. Don't get me wrong, I realize that a crossover would be ideal, but for now I can live with push/pull. In the future, I will go with crossover. A friend of mine installed 54's in the front, and retains the stock push- pull stearing.
