zero rate question???
Discussion in 'The Garage' started by twoslo4five0, Feb 21, 2007.
  1. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,614
    71
    Living in a dump, VA
    anyone running a zero rate in the front with push/pull steering...i would like to gain 1.5 inches in front but is there enough threads on the draglink???im gonna be running tuff country ez rides...
  2. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    How much lift are you going to get from your springs?
  3. twoslo4five0
    Oct 5, 2006
    6,614
    71
    4 inches...
  4. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    I've got 4" springs and a homemade zero-rate (cut down overload) with a aftermarket steering arm and all is fine.
  5. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    Yes you can run a zero rate, but you won't be able to move the axle forward/backward any because of the geometry of the stock steering.
  6. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,792
    100
    Paducah, KY
    You sure about that? I've been told otherwise.
  7. bigblazer87
    Dec 20, 2006
    333
    Elk Grove, CA
    I was told that it would mess with the push-pull geometry of the steering, and I see how it could screw it up. But, it's not like I've never been wrong before, so I dunno... if you can, I'd love to know.
  8. AJMBLAZER
    May 18, 2000
    22,792
    100
    Paducah, KY
  9. bigblazer87
    Dec 20, 2006
    333
    Elk Grove, CA
    Hmmm... people are all over the place. Although it seems it is possible. I just don't remember how much thread the factory draglinks had, because my truck has a Pro Comp dropped one on it. Thanks though. :D
  10. twoslo4five0
    Oct 5, 2006
    6,614
    71
    no one elce got any ideas???
  11. hunterguy86
    Jan 10, 2005
    2,477
    San Marcos, Texas
    I installed 6 inch front springs last night and my drag link was fine, so I dont see why 4inch front springs and zeros would be a problem.
  12. twoslo4five0
    Oct 5, 2006
    6,614
    71
    what about 6 inch with a zero rate???
  13. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    crossover and be done worrying about it
  14. AJMBLAZER
    May 18, 2000
    22,792
    100
    Paducah, KY
    I talked to Stephen at ORD today and he said he's done it with a 4" lift and the stock steering setup. It was still the so-so stock steering system but it worked.
    He also said that he couldn't see why the zero rates wouldn't work with a stock suspension and stock steering.
