Zero Rate question?
Discussion in 'OffRoad Design' started by TXsizeK5, Sep 5, 2002.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    Hey steve, can you guys custom make a tappered zero rate for a 6" lift? or will you guys just not do that? Thanks.
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    It's possible, but our machines are tied up with production work at this point so doing custom stuff like that is pretty tough to work in. Any idea what degree angle you need? We are looking into building production pieces with the angle built in. Knowing what you need could figure in to what we do.
  3. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    I really dont know much about angles... all i know is i need it for a 6" lift heh sry
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Well you need to give some more info. How is it lifted? What type of rear driveshaft, CV or plain Ujoint? If you don't know what angle it's at now and what you need to go to you're out of luck. Whit out knowing where it's at and where it needs to go to, then it's just a crap shoot or a wild guess.
  5. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    I have plain ole Ujointed driveshaft. 6 in lift with blocks and addaleaf... thats all the info I have
  6. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    If you have blocks they should be tapered already.
  7. ken
    ken 1/2 ton status
    1,244
    Anaheim, CA
    It would be cool to have zero rates fabbed that have an angle to them...say 6° or so. Since my 12" National front springs on my Suburban flex so much, the standard and even the ORD longer shackles do not cut the mustad! I had to fab some custom longer ones that move the spring away from the frame and allow it to compress/flex. Now I have too much of the good angle (is it called camber or caster?? I can never remember!!) and could use an angle to bring back the 60 front end into factory specs. What's say, Stephen?!???
  8. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I had shims made that were welded to the zero rates. Counter sunk bolt hole also. I use the zero rates all around, had the saggy ass look, the 3/8" shims were perfect for a level ride and dl correction.
