zero rate question
Discussion in 'The Garage' started by bad_bo_ti, Feb 16, 2003.
  1. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    if i were to make my own zero rate blocks, what is the biggest(thickest) i could go to put on the front and still be safe? thanks chris
  2. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    You will be limited by the strenght of the bolt holding them to the spring the taller you go the more load the bolt takes, so the taller you go the bigger the bolt needs to be, meaning bigger hole in the block and bigger hole in the spring for the bolt. I personally wouldn't go more than 2"s. But that's my opinion.
  3. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    i was thinking 2"s my self. i want to make em just to help me clear the 38's the just magicly showed up at my house all on wheels /forums/images/graemlins/wink.gif
  4. bad_bo_ti
    1,027
    OhiO
    i figured no bigger than 2in, what size center pin should i use? could I weld on spacers to the actual mounts on the front axle? then i could have a 1in axle lift and dont have to worry to much about a 2in zero rate breakin the bolt. just an idea. want a little more lift but want to do it safely! /forums/images/graemlins/thumb.gif
  5. jekbrown
    May 19, 2001
    45,026
    360
    Vancouver, WA, USA
    yeah, you could prolly run 2"... Id get the biggest strongest center pin I could find tho...
    j
  6. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Are you moving the axle forward while your at it if so, I would drill out the center pin hole in the spring and run a 7/16th grade 8 bolt since when you move the axle forward the center pin is recessed in the block. I made my own zero rates but I only needed 1" so I just used the 3/8ths center pin I would think 7/16ths would work for 2"s.
  7. bad_bo_ti
    1,027
    OhiO
    i dont know if i am moving it yet, i work for a company that has a bunch of different size center pins so i might try that route first. what does moving the axle foward do for the truck exactly?
  8. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    it helps keep the tires from rubbing the fenders when the shackle moves back when you hit an obstacle and gives you a better approach angle. I moved my front forward an 1 1/2 and the rear back an 1 1/2.
  9. bad_bo_ti
    1,027
    OhiO
    hmm, sounds like an idea to me, think i am sold on it now, now all i have to do is find some 2in solid bar, do they make a 2x2.5 solid bar? or will just have to get a 2x2 or a 2.5x2.5. would there be a problem with using 2 1x2.5 and welding them together? thanks for all the help.
  10. backyardbuilt
    May 28, 2002
    1,301
    Olathe, Kansas
    Not sure what the steel places carry but I would get one solid piece welding blocks together isn't a good Idea especially in the front, but if you drill another hole in the spring and use 2 bolts to hold it on it might work.
  11. bad_bo_ti
    1,027
    OhiO
    yea true, i want to safe not sorry, if nothing else i might see if can get a SOLID 2.5X2.5 and get it machined to 2in. thanks. chris
