Zero rate questions and advice.
Discussion in 'The Garage' started by MTBLAZER89, Dec 1, 2003.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Ok right now I am running 33's on 4" Superlift. I just got the ok to get some 37's in Jan with tax returns /forums/images/graemlins/thumb.gif. I figured I am gonna go with some zero-rates to minimize the cutting some. Here are my questions.
    1. I have shims in the rear can I still use a zero rate?
    2. Will my raised steering arm be ok or will I need more correction?
    3. I was thinking about the offset's for the front to move it forward 3/4-1". What are the benefits of this? Will I have to cut less?
    4. Anybody that runs a similar setup in the front did you have to do anything with the d-shaft.
    Any other advice would be great. I know I am gonna have to trim, but I just want to do as little as possible /forums/images/graemlins/thumb.gif
    Thanks.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    1. What I did in mine was have Az-Kickin make me a custom 1" off-set tapered zero rate /forums/images/graemlins/thumb.gif
    2. 50/50 chance, not much help here, but more than likely you'll be ok with what you have.
    3. Don't know here
    4. Don't know here either, as I'm still in process.
  3. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    Thanks.
    1) you could still use them, or have shimmed zero rates made, either way.
    2) hard to say on this one, back when I had a raised steering arm and 4" of lift, when the drivers side would droop while offroading, I pretty much lost all control of the vehicles front axle. x-over steering is what ya need if you really go offroad, if you dont, then raised steering and/or draglinks oughta work fine.
    3) Moving the front axle forward gives you a better approach angle and helps clear bigger tires. At full flex with the axle in the factory location, the first place tires tend to rub (if you've done the standard trimming to the front/back corners of the fender opening) is the metal that makes up the floor behind your brake/gas pedals. Naturally, cutting that metal isnt an option, so some people move their front axle forward a bit. generally, this is a good mod and cheap to do also.
    4) yeah, if you have 5" of lift and are still running a factory driveshaft, you're prolly gonna need to get it lengthened some. I know my factory shaft didnt have much slip left in it just sitting on flat ground when I had 4" of lift, let alone 5" + axle droop.
    j
  4. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    3. We moved the front axle forward an inch on my dad's m1008. He has a 4" BDS springs and a 1" zero rate, crossover steering and 36's and he only had to trim the front lip of the fender. The draglink doesn't hit the engine crosmember at all.
  5. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    So for the rear I can just get a 1" zero rate with a taper built into it?
    Yeah I know, but I am just not sure I wanna do x-over on a 10b front then end up going with a 60 later.
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Yes, just pm Bill(45acp), he did this for me. Tell him you want a tapered zero rate(at whatever taper you need)and have it 1" thick at the center pin location /forums/images/graemlins/thumb.gif
  7. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    yeah, dont throw $ at a 10 bolt... trust me, I know!!!
    j
  8. K1Orion
    K1Orion 1/2 ton status
    Jan 8, 2003
    812
    st.louis,MO
    Some body recently posted a cheap x-over for a d44/10bolt. I can't remember who but basically they used the older style front tie rod, the kind with one fixed end and one adjustable and a hole for a steering stabilizer. They reamed the hole for the stab to fit a tierod and flipped it over so the hole was on the pass side instead of driver. They used another tierod, bent it to shape and used it as the steering arm. They still had to swap the box and arm, but it was definitely cheaper than swapping knuckles.
    Here's the original thread crossover
  9. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    3" lift and I used a 3/4" driveshaft spacer for the front.
  10. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    That would be Thumper /forums/images/graemlins/thumb.gif
