Zero-Rate Springs on 1st Gen Vehicles
Discussion in 'OffRoad Design' started by trukman1, May 4, 2002.
  1. trukman1
    trukman1 1/2 ton status
    Mar 5, 2002
    129
    Ohio
    Can anyone give me the correct mounting locations (offsets) for front and rear axles to achieve the most tire clearence using the zero-rate springs? Remember, this is a 1969 (1st Generation) and will be different than the later years. Thanks for the help. Gary
  2. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    PM 72THING for detailed first gen info. You probably want to move your front axle forward. With your rear, it will depend on where you are hitting the fenders.
  3. SilverJim
    SilverJim 1/2 ton status
    Sep 23, 2000
    105
    Evergreen
    I've got the ORD shackle flip and 2" lift springs in the rear of my '70 Jimmy and I have it mounted in the middle (stock) location on the 0 rate spring. The tire is not centered in the wheelwell, it is closer to the front fang of the rear wheelwell. Tomorrow I'm going to mount the axle using the most rearward position on the 0 rate spring to see if that centers the tire and gives me a little more clearance.
  4. trukman1
    Mar 5, 2002
    129
    Ohio
    SilverJim, Thats the kind of information I've been looking for. Please let me know what position ends up centering the wheel/tire the best. Thanks, Gary
