Zero-rates and crossover question
Discussion in 'OffRoad Design' started by MTBLAZER89, Jan 20, 2004.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Ok I just get my tax return next week so I need to figure out some stuff. I want to get some 0-rates to move the axle an inch forward. I also want to get the ORD crossover setup. Will the axle relocation cause any interfernce problems with the crossover? Anybody run this setup? Another question is I have 4" springs plus a shim in the rear can I get the 1" 0-rates with the shim machined in to it? If so how can I figure out what degree shim I have? Thanks everybody.
    By the way this is on an 89 with 4" springs with 36's. 37's will be ordered in the next couple weeks /forums/images/graemlins/thumb.gif
    Ohh yeah and it's a 10b front
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    I have 0 rates and crossover on my truck, there's plenty of room between the sleeved rockrod and the spring. If you have a real thick spring then you might have problems.
  3. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Another question I can't seem to find the "kit" price for Dana 44/10b crossover kit. I found it for the D60, but not the 10b. Also need to do a steering brace. Is just the bolt in kit ok along with crossover?
  4. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    i've got mine on a 6" spring with a degree shim and zero rate. there's at least and inch to two between the ord draglink and the spring plate. no problems at all.
  5. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Zero rates with a D44/10 bolt crossover could be a problem, the D44 knuckle is shorter and typically leaves less room to play with. You should be able to do our 3/8" version to offset the axle, then worry about the crossover. The axle relocation shouldn't be a problem, just the height of the zero rate.
    For the rear, most of the shims will have the size stamped on them, otherwise, you get to do a little bit of geometry. Or you could measure it with an angle finder.
  6. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    "could be a problem" does that mean the spring could interfere with the draglink? What if I used one of those spacers under the steering arm? Would that solve the issue?
  7. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Yup, the draglink could hit the spring on the pass. side. A spacer under the arm would raise it up but then you have a spacer under the arm.
