Zero rates and crossover question
Discussion in 'The Garage' started by MTBLAZER89, Jan 20, 2004.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Ok I just get my tax return next week so I need to figure out some stuff. I want to get some 0-rates to move the axle an inch forward. I also want to get the ORD crossover setup. Will the axle relocation cause any interfernce problems with the crossover? Anybody run this setup? Another question is I have 4" springs plus a shim in the rear can I get the 1" 0-rates with the shim machined in to it? If so how can I figure out what degree shim I have? Thanks everybody.
    By the way this is on an 89 with 4" springs with 36's. 37's will be ordered in the next couple weeks
    Ohh yeah and it's a 10b front
    Another question I can't seem to find the "kit" price for Dana 44/10b crossover kit. I found it for the D60, but not the 10b. Also need to do a steering brace. Is just the bolt in kit ok along with crossover?
  2. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    TTT Anybody
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    To truely protect your frame, the weld in and bolt in kits are recommended.
    There is no bolt on crossover kit for a Dana 44 or 10 bolt because it requires different, flat top knuckles, machining, threading of the knuckles, etc. With the D60 you pull the plate off, bolt on the arm, and hook up the drag link. Not so with the 44 or 10 bolt, and thus no kit would really be complete without a different knuckle.
  4. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Alright I can understand that /forums/images/graemlins/thumb.gif
    Now does anybody run crossover plus their front axle 1" forward. Any clearance issues anywhere?
  5. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    i replyed in the ord forum
  6. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    cool thanks.. oh yeah other question for the rear. I can order 1" 0-rates for the rear with the shim machined into it correct? How do i figure out what degree my shim have now is?
  7. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    I replied in the ORD forum too, but didn't mention that the axle is 1.5" forward too.
  8. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I have the ORD crossover on my 10 bolt. I also have the axel moved foward 1". so far, it works good.
  9. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    OK one more question. With the zero rates will I need a steering arm spacer for draglink clearance??
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That's something I've been wondering myself. I ordered my crossover yesterday and I asked the guy and he said honestly there's no way to predict it, it depends on the thickness of your current springs. Not sure if it's the same for the 10 bolt, but I'd avoid the spacer at all costs if possible. My friend had one on a D44 years ago on the driver's side and it sheared the studs off at one point!!
  11. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif I'll keep that mind /forums/images/graemlins/thumb.gif
