Zero rates and front ends.
Discussion in 'The Garage' started by Z3PR, Jan 4, 2004.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Who all is running zero rates up front ???? any problems ????
  2. Stomper
    Stomper ΜΟΛΩΝ ΛΑΒΕ GMOTM Winner
    May 11, 2002
    3,767
    Iowa
    I am /forums/images/graemlins/cool.gif I'll let you know the first time it leaves the garage /forums/images/graemlins/deal.gif /forums/images/graemlins/rotfl.gif
  3. donimator
    donimator 1/2 ton status
    Jun 11, 2001
    444
    Tacoma WA
    I am running them on my D60 using the 1.5 in offset without any problems. I have 6in TC Springs and ORD Crossover Steering and it all works together flawlessly. /forums/images/graemlins/thumb.gif
  4. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    I put mine in after i got home so about 6 months now, pushed the axle foward 1.5"s and no problems, the only thing that was somewhat scary was redrilling the plates, i have a ten bolt and they are not flat on top so i had to make a quick jig to get that done
  5. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I am running them up front, and have had no problems. I just used them for extra lift, not axle relocation. /forums/images/graemlins/thumb.gif
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    ditto!
  7. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,609
    559
    Wasilla AK,
    yep I run them and so does my buddie on his blazer we have them for axle relocation no problems yet and we've jumped the blazer about 5 ft in the air /forums/images/graemlins/eek.gif
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Thanks for all the quick replys. I'm now positive I'll relocate my front axle 1.5" forward. I'm waiting too see if this 81 K30 deal is going to work out or not. Be really cool to go 1 ton. /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  9. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    ditto!
    same here /forums/images/graemlins/grin.gif
  10. 88jimmy4x4
    88jimmy4x4 1/2 ton status
    Oct 19, 2003
    947
    3
    Houston, Texas
    Why did you have to re-drill the plates with the zero rate?
    I was under the impression that its a bolt on mod even when relocating.
  11. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    To answer the first question, as soon as my rear zero-rates get here from ORD and I get my BDS springs installed I will let you know. I am moving mine 1.5" forward for better approach angle.
    Question two:
    You have to re-drill the plates if you move the axle forward because the spring plate moves forward with the axle, so the centerpin will not sit in its factory position. ORD zero-rates this talks about redrilling also /forums/images/graemlins/thumb.gif
  12. Judd
    Judd 1/2 ton status
    Sep 27, 2002
    175
    N.E. Ga
    I have the zero rates in the front and used the 1 inch forward position. I had to grind on my front plates to give the bolts that hold the zero rates enough clearance so the axle plates would bolt down flush.
    BTW. I only moved the axle 1 inch forward and I barely had enough adjustment in the {hmmm,, I think it's the steering link, goes from the steering gear arm to the knuckle arm}. I would have to had taken the link apart and cut a bit off of each threaded side {maybe .25-.50 off each threaded end} in order to have equal steering both ways.
    So far so good as far as Murphy's concerned! /forums/images/graemlins/thumb.gif
  13. sapper
    Jul 11, 2001
    3,052
    NoVa
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  14. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Good thread, usefull info. Thanks everyone. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  15. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Just thought I would share my experience with a block made similar to the Zero Rate - I have a friend who is a machinist so I had him make a pair of blocks like the Zero Rate but with some degree in them like a degree shim. I removed them recently when I went back to all spring and one of the center bolt was bent at the bolt head. Posted about this a while back and someone said bent center pin bolts aren't too uncommon but wanted to share my experience with a block used up front like the Zero Rate.
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Sure the taper didn't contribute to the bent bolt?
  17. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Wouldn't surprise me if it didn't have an affect on why it bent.
  18. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    If they didn't have a flat cut for the head of the bolt, it would bend the bolt.
