Zero rates, gulp..On a Dodge???
Discussion in 'OffRoad Design' started by Rusty68, Apr 17, 2003.
  1. Rusty68
    Rusty68 1/2 ton status
    Jan 22, 2003
    116
    Elko, Nevada
    Ok, I am coming out of the closet here so dont beat me up to bad. I own a 93 Dodge cummins 4x4 that I have added a massive winch bumper to. The front is sagging a bit due to age and the weight. I would like to level it out a bit and have considered the front spacers. First of all, are they really safe to use on a 7300# truck? If so, the dodge Dana 60 has a weird u-bolt and stud arangment to hold the springs down on the diff side. Are 1 inch longer studs available from you? Thanks for any help.
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I don't see where you'd have a problem with the zero rates, the truck's heavy but you wouldn't hesitate to add a couple of leaves to the pack would you? Not much difference between a couple of thin add a leaves and one thick one.
    We don't have longer studs, you'd have to pull them and go with a standard bolt instead. Kind of a pain but a necessary evil.
