zero rates in need assistance.....
Discussion in 'The Garage' started by RootBreaker, Mar 28, 2005.
  1. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    aight... my zero rates came in while I was away... so now I want to put them on... Once it stops raining...
    anyhow... Reading the directions... I only have a question..
    To move the axle forward 1"... I need to remove my center pin from my leafs...
    The instructions say to shorten the center pin to about 1" in length... which pin am I shortening.. the one that I am pulling out?
    so then I am going to take the 3/8 bolt and go through the zero rate to the hole I want for offset... and then put that into the pin hole??
    sorry for the stupid questions.. I have been trying to do all my own stuff now instead of paying someone else... Computer geek that wrenches.... :grin:
    anyone have easier instructions for me to use???
    Jeff
  2. sweetk30
    Nov 1, 2004
    25,538
    538
    horseheads , ny 14845
    never reuse a centerpin. and most of the time thay need to be cut out.
  3. RootBreaker
    Nov 29, 2001
    5,117
    173
    aight.. not even if it only has 800 miles on it???
    my leafs are new superlifts.... but guess I ll have to figure this out.. wont be doing it until friday most likely... :grin:
  4. sweetk30
    Nov 1, 2004
    25,538
    538
    thay are grd 2 bolts. and most spring comp bend the threads over to help hold the nut in place.
