Zero Rates on 89 K-30
Discussion in 'OffRoad Design' started by 79Silv4x4, May 14, 2005.
  1. 79Silv4x4
    79Silv4x4 Registered Member
    Aug 14, 2002
    50
    Lawton, OK
    Can the 1" Zero Rates be used on the front of an '89 K-30 cab.chassis dually?
  2. Bob87Burb
    Bob87Burb 1/2 ton status
    Apr 19, 2003
    141
    RI
    As far as I've read, yes. They're not like the cheapo lift blocks, the Zero Rates have holes drilled in them, and you remove your existing center pin and install the ZR's with a supplied new center pin. This makes them part of the spring pack, and the safest block out there. I've had a pair on the rear of my Burb for two years now, with no issues whatsoever. Top notch stuff.
  3. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Don't see why not, check your ubolt lengths but otherwise it's no different than bolting in a couple of full length add a leaves, except for the stiffness.
