Zero rates or add-a-leaf?
Discussion in 'The Garage' started by NcRedneckJimmy, Jul 21, 2006.
  1. NcRedneckJimmy
    NcRedneckJimmy Registered Member
    Apr 1, 2006
    12
    Parkton, North Carolina
    I have a stock Jimmy with 31X10.50 tires on it right now, I want to put on some 33X12.50's on it. I know they will fit, or should. I was also thinking of putting on either some add-a-leafs or a zero rates, for some extra lift. Which would be easier/cheaper/better? I am leaning towards the zero rates.
  2. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    i run aal i realy dont like them. not much lift maybe 1-1.5 inches. and it rides realy stiff.
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Go with some zero rates. Add-a-leafs will work, but will sag eventually like springs do, zero rates will never sag and will always give you a 1" lift.
  4. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
  5. NcRedneckJimmy
    Apr 1, 2006
    12
    I have e-mailed you. Thanks
    I think I am going to go with the zero-rates! But which brand should I get either ORD or I sall some on Blackwidowperformance.com? But they are listed as add-a-leafs but look the same as zero-rates, and they are cheaper?
  6. '71k204x4454
    '71k204x4454 Registered Member
    Dec 28, 2004
    60
    Hood River Or
    I've tried to order Black widow but they won't return the calls. So even if they are cheaper good luck in getting some. ORD is great to work with and quick to get items from them.
