Zero rates questions
Discussion in 'OffRoad Design' started by pomai, Mar 27, 2006.
  1. pomai
    pomai 1/2 ton status Premium Member
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    Has anyone had clearance problems between the drag link and the RH spring when useing the 1" zero rates in the front end Dana 60.
    Has anyone moved there front end 1 1/2" forward useing the 1" zero rates. Did that cause any problems?
    Thanks, Ed
  2. YZEATER
    YZEATER 1/2 ton status
    Jan 21, 2005
    2,358
    TARENTUM, PA
    i'd like to know this also. i'm doing 52" 's in the front and don't know if it will clear with zero-rate or not. i wanted the extra 1" for lift but if i do that i might need a steering block spacer.
  3. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I run that setup. 1.5" forward, crossover, high steer.I have had no clearance problems. What kind of crossover are you using.
  4. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,069
    206
    Colorado
    I know that some spring packs will have problems and some will not. There are a bunch of variables that play into this.
    Lift, springs, axle location, drag link ect.
  5. pomai
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    I'm using the OffRoad design cross over and soon I'll be installing there High Steer. My tire is rubbing against the lower rear area of the front fender when it articulates. I wannted to try the zero rates and hope that helps. What lift do you have?
    Thanks, Ed
