Zero Rates ??'s
Discussion in 'OffRoad Design' started by Big10, Aug 4, 2003.
  1. Big10
    Big10 Registered Member
    Aug 30, 2002
    84
    Georgia
    Zero Rates ??\'s
    Im sure this has been covered, and i have searched, but found nothing to fit "my" application. I have a 4" rough country lift (all spring), my t-case has not been moved/lowered. The driveshafts have not been altered either, I have about 1 inch of spline showing on the front and the back shafts. I want to add zero rates to the front to allow a little more clearance, and some in the back to keep the truck level. Am I going to run into trouble with drive shaft length? Pinion angle? vibration? thanks for any input.
  2. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Re: Zero Rates ??\'s
    Same here, so I'm wandering the same deal (before I get the 4" all spring lift in) /forums/images/graemlins/deal.gif
  3. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Im running Superlift 4" springs and a ORD flip, when i added the zero rates i mover the front foward the 1.5"s and had to get the shaft extended 2"s, the back was fine but the flip might be deffernt than your springs as far as pinion angle gos
